TK-7150 programming for packet help needed
olson339
Brick, NJ
Hello
looking for some assistance on programming a tk-7150. Specifically the PTT function. I have the programming software and have looked at all the tabs and fields. I would like to use the rig for packet radio. Under optional features, Extended functions there are some pins defined under connect to modulation line
that will allow me to change the function. But unsure where to assign the settings below. Any help is really appreciated
PTT = You can use one of the Auxiliary input pins, however you will need to program that pin to do PTT. Pin 12 = AI4, Pin 13 = AI2, Pin 21 = AI1, Pin 24 = AI3
Audio out = Pin 17 is filtered audio output, 700mv peak to peak There is also a detector output at pin 19.
Audio in = depend on what you want. MI2 (Mic Input 2) is on pin 6, but you'll need to program the radio to use that audio input.
Ground = Pin 7, Pin 11, Pin 18, Pin 25 (specifically Mic Ground)
73
Art N2AJO
ramal121
Lots and lots of watts
Calif Whine Country
Pick an aux in and program it for External PTT Voice
Rx audio - since 1200 baud packet is AFSK use the AFO filtered audio on pin 17.
TX audio - use MI2 mic input. Pre emphasized and will match all other radios using AFSK (mostly). Be aware spec to this input is 5 mV rms.
If you have a separate mic ground land it on pin 25. If only one ground line use either 7, 11, or 18.
Should be good to go.
