TK-7150 Question
Metrofire31
Auburn-Opelika, AL
I've just purchased a Kenwood TK-7150 (VHF) mobile. My question is this: I don't see a remote speaker jack on either the radio or the remote head. Is it possible to connect a remote speak for better audio? If so, what will I need to order?
firefighter728
Kentucky
Kenwood TK 7150
The external speaker hooks up to the 6 pin molex connector on the back of the radio. Looking at the back of the radio the pins go
Left pin column bottom to top, pins 1, 2, 3
Right pin column bottom to top, pins 4, 5, 6
Ignition sense is pin 1
Internal speaker - wire jumper in place pins 5 and 6
External speaker - remove jumper, speaker wires in pins 4 and 5
Pins 2 and 3 are for speaker output "B"
This is used for auxillary speaker when public address is programmed in software and switches to these pins when PA button is pressed.
All you would need are some pins from your local radio shop that fit the connector and the speaker
ramal121
Lots and lots of watts
Calif Whine Country
Look at the back of the radio, there is a white 6 pin connector with a wire loop. To add an external speaker, the loop is removed and the external speaker is plugged in there. Kenwood speaker KSC-5 comes with connector pins on the ends of the speaker leads.
