I recently purchased an R1-2023 (Blue Box) for linking my TK-7180 to Zello
None of the "plug-and-play" radios offered by the seller can program "splinter" frequencies so my TK-7180 is it.
My issue is correctly wiring the R1-2023 connector to the DB-25 on the mobile radio.
The R1-2023 data connector is as follows:
I've also got the 6-pin to 16-pin conversion board:
I'm pretty sure R1-2023 to 16-Pin Conversion Board is straightforward.
Can anyone help me fill in the 3rd Column?
Even GND...do I use Pin 7 "GND" or Pin 25 "MIC GND"?
I understand that I'll likely need to go into the KPG-89D software and program some of the pins for a specific function.
R1-2023 Data Cable | 6-Pin to 16-Pin Conversion Board | Kenwood DB25 (TK-7180H) |
1 - AF Out | Pin 11 | |
2 - GND | Pin 7 | |
3 - PTT | Pin 3 | |
4 - Not Used | Not Used | |
5 - AF In | Pin 2 | |
6 - SQL | Pin 8 | |
