TK-7180 Pinout for the DB25
KC1ART
Yarmouth, ME
I recently purchased an R1-2023 (Blue Box) for linking my TK-7180 to Zello
None of the "plug-and-play" radios offered by the seller can program "splinter" frequencies so my TK-7180 is it.
My issue is correctly wiring the R1-2023 connector to the DB-25 on the mobile radio.
The R1-2023 data connector is as follows:
I've also got the 6-pin to 16-pin conversion board:
I'm pretty sure R1-2023 to 16-Pin Conversion Board is straightforward.
Can anyone help me fill in the 3rd Column?
Even GND...do I use Pin 7 "GND" or Pin 25 "MIC GND"?
I understand that I'll likely need to go into the KPG-89D software and program some of the pins for a specific function.
R1-2023 Data Cable6-Pin to 16-Pin Conversion BoardKenwood DB25 (TK-7180H)
1 - AF OutPin 11
2 - GNDPin 7
3 - PTTPin 3
4 - Not UsedNot Used
5 - AF InPin 2
6 - SQLPin 8
KC1ART
Yarmouth, ME
I’ve definitely been though that but it couldn’t be as easy as “SQL” on the 6-Pin equals “SQL” on the DB-25.
So there’s a terminology, or pin description, that I’m not able to tie together.
The "indepth" manuals are probably going to have what you want in the way of information. Specifically, the TK-2180/7180 MOD manual.
Pin numberSignal nameInput/ OutputDescription
1NC-No connection.
2
RXD1
Input
Serial Data Input 1
RS-232C Level, Input voltage range ±30 V max,
L = less than 0.4 V, H = more than 2.4 V, Zi = more than 5kΩ
3TXD1OutputSerial Data Output 1
RS-232C Level, L = less than -5 V, H = more than 5 V, Zo = more than 5kΩ
4
AUX I/O 9
Input/ Output
Auxiliary I/O 9
Input: Active Low with 47kΩ pulled-up to 5 V, L = less than 0.8 V, H = more than 4.2 V Output: Active Low with 47kΩ pulled-up to 5 V, 0.2 mA max, L = less than 0.3 V, H = more than 4.8 V (no load)
5
DI
Input
Data Signal Input
60% of System Deviation with 2 Vpp input,
Input Impedance = 10kΩ or more, DC coupled, Frequency Response = +2/ -3 dB
6MI2InputExternal Mic Input: 60% Deviation with 1 kHz 5.0 mV ±2.5 mV Input signal
7GND-Ground
8AUX I/O 8Input/ OutputAUX I/O 8: Same Level as AUX I/O 9.
9TXD2OutputSerial Data Output 2:
C MOS Level, L = less than 0.7 V, H = more than 4.2 V (25kΩ load), Zo = more than 1kΩ
10RXD2InputSerial Data Input 2
C MOS Level, Input voltage range = +5/ 0 V max, L = less than 0.8 V, H = more than 4.2 V
11GND-Ground
12AUX I/O 7Input/ OutputAuxiliary I/O 7: Same Level as AUX I/O 9.
13AUX I/O 6Input/ OutputAuxiliary I/O 6: Same Level as AUX I/O 9.
14SB-Power Output in conjunction with the Power Switch DC 13.6 V ±15%, 2.0 A max
15AUX OUT 2OutputAuxiliary OUT 2
Active Low, open collector 500 mA max, Default = None, L = less than 0.3 V
16AUX OUT 1OutputAuxiliary OUT 1
17AFOOutputRX Filtered Audio Output
DC coupled, AF low level output 700 mVpp typical while receiving standard modulated signal.
18GND-Ground
19DEOOutputDetected Signal Output
DC coupled, 740 mVpp typical while receiving standard modulated signal.
20AUX I/O 5Input/ OutputAuxiliary I/O 5: Same Level as AUX I/O 9.
21AUX I/O 4Input/ OutputAuxiliary I/O 4: Same Level as AUX I/O 9.
22AUX I/O 3Input/ OutputAuxiliary I/O 3: Same Level as AUX I/O 9.
23AUX I/O 2Input/ OutputAuxiliary I/O 2: Same Level as AUX I/O 9.
24AUX I/O 1Input/ OutputAuxiliary I/O 1: Same Level as AUX I/O 9.
25ME-Mic Ground
You are going to need to set your pin function in KPG-89. You'll need to program an AUX pin for your PTT and the "Squelch" may be looking for a Carrier Operated Relay function. Those are all options in the "Extended Function" section of KPG-89.
You may also have to add some adjustability to your audio levels.
KC1ART
Yarmouth, ME
I went with the following.
Keying Zello causes the TK-7180 to turn off and re-boot.
Keying the TK-7180 does not bridge/transmit anything to zello.
I also switched Pin 6 and 17 in case I was thinking about AF in/out incorrectly. Same result.
1 - AF OutPin 11Pin 17
2 - GNDPin 7Pin 7
3 - PTTPin 3Pin 4 (Programmed Input Ext PTT Voice)
4 - Not UsedNot UsedNot Used
5 - AF InPin 2Pin 6
6 - SQLPin 8Pin 24 (Programmed Output COR)
KC1ART
Yarmouth, ME
I also got a warning to not connect the TK-7180 to a PC when pins 4, 8, 20 and 22 were programmed as inputs which could cause a malfunction. So I changed the PTT to Pin 21. Same result.
ramal121
Lots and lots of watts
Calif Whine Country
Whoa, stop! If Zello keying the PTT line causes the radio to reset that is a huge problem. Disconnect Zello and confirm it's logic level switches between 5 volts (and no more) and ground. Resetting is not good and can damage the Kenwoods I/O.
Also reset on radio transmit could be a power supply too small to supply the needed current by the radio.
KC1ART
Yarmouth, ME
The Zello side doesn’t produce any voltage.
The TK-7180 PTT pin outputs 5v and the Zello controller shorts it to ground which I’m pretty sure it’s supposed to.
Checking the power supply, it’s 14v when the radio is off. 10.8v when the radio is on. So maybe you’re right that it’s undersized and the radio is turning off because of under-volt when transmitting.
What kind of power supply, exactly, is this?
Standby current on these radios is only 400ma, so if it's dropping from 14 to 10.8 just under that amount of load, not surprising the radio is restarting when asking it to do anything.
KC1ART
Yarmouth, ME
It’s a very old Sonar PS-2929.
I’m really not sure of the specs, and there’s no nameplate. Though it was working just fine last week when I had a Yaesu FT-7900 hooked to it.
Check all your connections. Especially any crimp connections or fuse connections.
No idea what the specs are on that power supply, but that much voltage drop is not a good sign.
KC1ART
Yarmouth, ME
I’m suddenly reminded that this is probably the same radio I had installed in a vehicle, and it would intermittently do the same thing (turn off and reboot) if you tried to transmit with the vehicle stopped/idling, but would work if you were driving down the road.
Thinking there’s something wrong with the radio itself, so I’m gonna park this thread, find a new radio and try again some other day.
wd8chl
***SQL is NOT what you want! You want either COS or TOS, depending on whether you're using CTCSS or not.
That's the standard terminology for that function. SQL I have seen as either a squelch level adjust-maybe something that toggles between two different settings, or a monitor function that disables CTCSS decode.
AM909
Radio/computer geek
SoCal
Where did you measure the voltage? At the power supply? If so, either the power supply is toast or the radio is drawing tons of current that it's not supposed to draw at idle (pretty unlikely failure mode IME). Can you measure the current draw of the radio (stick a high-current ammeter in series with the + lead)?
@wd8chl : isn't TOS always the better choice? Doesn't it just follow COS on a channel that's programmed for carrier squelch?
wd8chl
Yes it would. And normally, you're right. The exception is when you're using a controller that has separate inputs for COS and TOS, and can utilize them in different ways. Most amateur style controllers are like that.
KC1ART
Yarmouth, ME
Closing the loop on this thread for anyone in the future; I was finally able to get my TK-7180 working with Zello.
The issue with the radio turning off on TX was the old power supply. Someday I may trace out the issue, but for now I just bought a new one.
Here’s the final table of pins I used between the different interfaces:
2 - GNDPin 7Pin 7
3 - PTTPin 3Pin 21 (Programmed Input, Ext PTT Data)
5 - AF InPin 2Pin 5
6 - SQLPin 10 ***Pin 24 (Programmed Output, TOR, Active High)
*** - talking from Zello to the radio was easy, but I had the hardest time debugging why the radio wouldn’t talk back to Zello.
I finally found this YouTube video:
My 6-pin to 16-pin conversion board didn’t have a trace to the 12v pin! So I broke out the soldering iron and placed a jumper (pic attached). I picked Pin 10 on the board to Pin 6 on the R1’s data cable. Then programmed Pin 24 on the DB25 cable to pull it Active High (+5v).
Now everything works perfectly!
