etherxrally
- Joined
- Sep 16, 2012
- Messages
- 8
I have searched all over the net about re-tuning the vco on the tk-730's. I am trying to get more power out of my tk-730 at 145-148 mhz to use as a ham rig. I took off the metal cover to see if i could add a trimmer to the tx vco for adjustment. As many of you know there is only a rx adjustment inside even though there is a hole for the tx side. I guess what Im looking for is if anyone else has modded this to have a adjustment for the tx. if so what value trimmer did you use? tI looks like I can un-solder the component that is at the base of the tx coil and add a trimmer in series like the rx vco has but I have no clue what value they are or should be. Any one have any insight? Thanks
