Kenwood: TM-V71A Programming
KC5TOO
Mesquite, TX
I'm having trouble programming my Kenwood TM-V71A. I have reset the radio back to its factory settings. I can enter VHF frequences in group 0-99. When I enter UHF frequency into group 101-199 and push the key the mike the Home Screen comes on for a second and goes off and the frequency is not stored. I'm not sure what's wrong. Any help would be appreciated.
bharvey2
It's been a while since I've programmed one of my V71As and I almost alwys do it via a computer but one thing comes to mind: As you probably know there are two bands A and B (more accurately I'd say its left and right) The A band can accept low VHF like, air while the B band cannot. Does this apply to your programming task?
KC5TOO
Mesquite, TX
Thank you for the reply. I finally figured it out. There was a data setting set wrong in the menu. Made the correction and all UHF frequencies programmed correctly in the assigned group.
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
The one downside to the V71a that I absolutely hated. The lack of real memory zones, and that the group size was fixed.
I still liked the TM-V71a better than the FT8800 though.
bharvey2
That was a shortcoming and a nuisance if you use it for travelling to any degree. I use one of mine as a base station so the channel pool never changes. I have another in my truck which doesn't usually stray too far from home. When I travel I lean toward commercial radios which do a better job of keeping all of my programmed channels sorted. Overall though, I think it's one of the better purpose built 2M/70cm ham radios.
kayn1n32008
Sector 001
I sold my V71a to a friend. I really like digital modes, DMR and P25 specifically. I run almost all commercial gear now. The cha. Channel capacities at, or approaching 1000 mean that I don't have to change programming very often, even for my travels now.
kayn1n32008
Sector 001
I agree. I specifically sold my FT8800 to buy the TM-V71a for a couple reasons:
1: Cross band repeater. The TM-V71/D710 have the best cross band repeat of all the hamster offerings.
2: Control head layout.
3: back lit buttons.
Now that I've been using only LMR mobiles for close to 2 years, I don't think I could ever go back to ham mobiles. I'd rather have separate VHF and UHF mobiles(although a NX5700/5800 dual deck setup would be nice, there is no way I'll be able to afford it.
bharvey2
While I prefer the commercial radios for day to day use, the ham radios like the V71A still have their place in certain circumstances. In my daily driver, I have a part 90 radio but at home, I often run both a Part 90 and a V71A side by side. The V71A allows changes "on the fly" while commercial radio usually don't. Even still, my go to VHF/UHF ham radios have been Kenwood and they are all but out of that market at least with regard to mobiles. Sign of the times I guess.
kayn1n32008
Sector 001
If I need a VFO I'll bring my IC-92AD or ID-51. I don't ever think I'll put a ham rig in a vehicle again.
