Tone Out Freqs
KD0NDO
does anybody know what the freqs of the tones are for Anoka Champlin fire department (ACFD) i believe it is a single long tone but i dont know the freq
wogggieee
Hugo , MN
There is a rather lengthy thread regarding tone-outs over on the scanfan forum. Do a search of that forum. There hasnt been any activity on that thread for a while, but there is a good chance that what you're looking for is there.
Raven95150
Nowthen, MN
I don't know the tones, but just from listening on VHF I think they have at least 4 different tones.
Station 1 (Anoka)
Station 2 (Champlin)
General Alarm (Both stations)
Duty Officer
I believe the Duty Officer tone is the one that is a single long tone, the others are all 2 tones.
JASII
Memory Capacity
Tone Out Frequencies
I can do a Tone Search with my Uniden Bearcat BCD996XT? Are they dispatched by Anoka County on 154.280 or Hennepin County on 154.285?
KD0NDO
cool thank you very much the freq is 154.280 all of the sets of tones mentioned above would be nice to have.
btw i hear tones then i here the dispatcher dispatch SBM rescue or something like that do u know what that is
JASII
Memory Capacity
So far I have heard:
-Coon Rapids Rescue Station 3: Tone A: 368.7 hZ Tone B: 457.7 hZ
-Andover Fire Station 1: Tone A: 511.1 hZ Tone B: 538.8 hZ
-Columbia Heights Rescue: Tone A: 480.5 hZ Tone B: 483.4 hZ
I also compare what is decoded to the Midian Chart http://www.midians.com/pdf/tone_signaling.pdf
So really it is
-Coon Rapids Rescue Station 3: Tone A: 368.5 hZ Tone B: 457.9 hZ
-Andover Fire Station 1: Tone A: 510.5 hZ Tone B: 539.0 hZ
-Columbia Heights Rescue: Tone A: 483.5 hZ Tone B: 483.5 hZ
Policechaser, do you have a Uniden Bearcat with Fire Tone Out capability so that you can try these and verify what I have found?
KD0NDO
sorry no i am old school, at least until we go digital here in wright co.
thanks
JASII
Memory Capacity
I parked on 154.280 overnight and my ARC-XT PRO logged a number of pairs of tones, but it sounds like you have no real use for these then? I will clear the log later unless somebody is interested in this information.
KD0NDO
i have a use i have a minitor pager that needs to be programed
hamelfire
Hamel MN
They both are dispatched thru Anoka county even though Champlain is in Hennepin county.
JASII
Memory Capacity
Here are some logged pairs from over the weekend. Anoka County Central Communications seems to hit the 1000 hZ Alert Tone first and then the trip the pager tones. These are the actual logged hits. If someone wants to work with these they should compare to the Midian Chart first, correct to the standard tones, and then enter these in a 396/996X or XT to see what departments are being paged on these. I ran this while I was sleeping and away from home, so although they are tones that were transmitted, I don't know which departments they are for.
A : 329.6Hz / B : 433.2Hz
A : 365.5Hz / B : 368.4Hz
A : 352.1Hz / B : 349.2Hz
A : 482.3Hz / B : 458.3Hz
A : 388.4Hz / B : 369.0Hz
A : 369.2Hz / B : 433.6Hz
A : 388.2Hz / B : 368.2Hz
A : 388.8Hz / B : 368.4Hz
A : 389.5Hz / B : 368.6Hz
A: 368.5 hZ/ B: 457.9 hZ Coon Rapids Rescue Station 3
A : 369.2Hz / B : 367.6Hz
A : 367.0Hz / B : 411.0Hz
A : 368.5Hz / B : 409.9Hz
A : 386.8Hz / B : 368.2Hz
A : 485.0Hz / B : 458.4Hz
A: 507.7Hz / B : 538.8Hz
A : 509.5Hz / B : 510.0Hz
A : 368.5Hz / B : 433.7Hz
A : 330.0Hz / B : 329.8Hz
A : 386.9Hz / B : 368.8Hz
A : 483.5Hz / B : 483.5Hz Columbia Heights
A: 510.5 hZ/ B: 539.0 hZ Andover Station 1
A : 616.4Hz / B : 585.1Hz
A :1231.4Hz / B :1466.1Hz
A : 330.4Hz / B : 483.0Hz Ham Lake
JASII
Memory Capacity
Anoka Champlin Fire Station 1 (Anoka)
Anoka County Central Communications just toned out Anoka Champlin Fire Station 1 (Anoka) on
A : 321.2Hz / B : 422.1Hz
The call was for the City of Anoka. When I look at the tone chart that translates to:
A : 321.7Hz / B : 422.1Hz
Now I guess that this begs the question, what other pairs do they have or use? Could they have one more set for Station 2 in Champlin? Could they have different sets for All Call, Chiefs, Duty Crews? Anyway, that is what I have found so far for Anoka Champlin Fire. Is anybody here able to confirm that the tones I have decoded are correct?
This popped up for Bethel Rescue:
A : 539.0Hz / B : 410.8Hz
This popped up for Centennial Duty Officer:
A : 433.7Hz / B : 433.7Hz
Another one possibly for Centennial, but I didn't catch which station. It looks like they have three stations. Based on units checking in I suspect it is for Station 3.
A :1231.7Hz / B :1742.7Hz
JASII
Memory Capacity
From the overnight log.
A :1226.3Hz / B :1464.8Hz Centennial Rescue Station 2 for Lino Lakes
A : 330.4Hz / B : 410.5Hz
A :1230.8Hz / B :1742.8Hz
A : 511.2Hz / B : 538.8Hz
A : 368.2Hz / B : 368.6Hz
A : 434.2Hz / B : 457.6Hz
A : 388.9Hz / B : 368.7Hz
KD0NDO
ok i have some new info there is only 2 fire stations. once again thanks to all that are helping me
