I've been fiddling around a bit lately with using the Tone-Out feature on my SDS200 and have this situation:
I'm monitoring a nearby rural county fire channel (155.805 MHz) that uses QC2 tones with everyone using B=389.0 Hz but each department (about 10 of them) having their own A tone. There is typically a dispatch at least every couple hours, often more frequent, but rarely less frequent. I've got good signal strength with RSSI generally about 100 or less. One department in particular is the most active and usually gets several tone-outs per day. If I monitor the channel normally, I get excellent reception.
My SDS200 will detect only one or two, sometime zero tone-outs per 24 hours and I have no explanation as to why so few. I am logging with ProScan and the detected tone frequencies match what is published and what I have programmed. I've had legitimate detects on the most active department, but only a couple over several days, far fewer than I think would be normal.
For a time (several hours or more) I set it up in search mode (A=0, B=0) and got no hits at all.
I monitored a different nearby county (typically more active than the first) in search mode for the better part of a day and got no hits whatsoever which seems completely unreasonable.
I've used tone-out monitoring on my BCD325P2 just fine, but this is the first time I've set up the SDS200. I am at wits end as to why I feel like I am missing so many tone outs.
Any ideas appreciated...
