N_Jay said:
Probabaly 10 miles at the most (52,000 feet to a aircraft)
More likely to a satellite. A downed pilot in enemy territory (where he himself was just shot down) seldom has friendly jets slowly circling
directly overhead listening until his SOS is heard. Even at a close 10 miles out and 52000 feet, that's already 14 miles away.
Its hard to write here about the modern gear used for the truly covert stuff. By many accounts, there are currently surveillence teams in Iran. One wouldn't expect their comm gear to have full specs and detailed technological data up on the web or otherwise available for forum and message board discussion. One can instead look at similar technology on the open market and extrapolate the desired figures.
Current implementations of wireless networking equipment (802.11B/G) that I'm sure many here on the forum are familiar with use direct sequence spread spectrum (DSSS). 100mW (20dBm) is a typical output power for wifi cards. A typical card is the
Cisco Air-PCI 351. The manufacturer quotes a 2000ft foot outdoor range at 1Mbps.
Its not a perfect analogy for a number of reasons.
1. Note that this is without an external antenna which is only going to improve things.
2. Also note that this is for data 1Mbps. Voice would only require some small fraction of this amount of bit rate, especially with an efficient vocoding scheme and DSP (compression, filtering, etc).
3. Data being transfered by WiFi is extremely intolerant of bit errors..unlike voice.
4. WiFi data is limited to certain channels 22MHz wide. Government gear has no such limitations. This is important because the wider the bandwidth in a DSSS system for a given power, due to a property called process gain, the longer the range (with some limitations).
5. WiFi cards need to be competitively priced. Government equipment is famously exceedingly expensive. When it comes to intelligence gathering, cost is no object.
Take these considerations with the knowledge that the WiFi card is a common consumer product compared to a spooky government radio.
Compare any state of the art consumer product to a state of the art gov/military product (imaging satellites/performance jets/spacecraft/databases) and you can begin to imagine the possibilities.
