Unless I'm wrong, 50 watts ERP is the max you can run using GMRS. Your answer is going to be to figure the combination that will give you as close to 50 watts ERP at the antenna as possible.
50 watts ERP is a decent amount of power. What you really need to do to make this work is to get your antenna as high as possible.
When it comes to the GMRS, at 50 watts, it will talk as far as the line of sight plus a little, so adding more power is not going to make a lot of difference. If you have a lot of mountains, more power could help with signal bouncing off of the mountains, but in a more flat area, 50 watts and height will get you the most distance. You could have a 200 ft tower and 50 watts will talk as far as the line of sight from the tower, more power is not the answer, antenna height is.
John
John
