Tower sites
mburge
Warsaw mo
Programing Bcd 325p2 with Free Scan...Im in Benton County Mo..I All I want is Benton county and Troop A ...question is do I have to put in all tower sites? I have the NXDN upgrade..and yes I understand some of Benton is has E ...Thank you
mburge
Warsaw mo
Freescan has been abandoned for years now and does not handle NXDN. Proscan is the best alternative with $50 purchase cost.
Alternatively, you could learn to program by hand, which is not hard once you get the hang of it. Naming stuff by hand gets tedious, though.
sonm10
Central MN Monitor
Sauk Centre, Minnesota
All county law enforcement is encrypted. No scanner will decrypt.
The only other thing I saw which is NXDN is Warsaw EMS, not encrypted. All fire department are conventional analog with a PL tone.
mburge
Warsaw mo
Yes I know..not hearing EMS with Freescan.. Is there any other programming other than Proscan..that will work? its $50...How about ARC XT BASIC $39 any good?
scannerowner
NW Missouri
If nothing hears, then nobody affiliated with the sites. I hear Troop A Dispatch 1 and 2 regularly with one site near me and not on another since it doesn't have any Troop A cars to affiliate with it. Since it looks like Benton County is on the border of Troops D and F, it may not have affiliates of Troop A on those sites at times.
tvengr
Well Known Member
Baltimore County, MD
Warsaw mo. Benton County Mo
Here are 2 ARC-XT files for Benton County. The first is MO Highway Patrol troops A, D, and F talkgroups on the MOSWIN trunked system. Pressing 1 on the scanner keypad of will toggle the MOSWIN Cole Camp site on and off. Pressing 2 will toggle the MOSWIN Warsaw700 site on and off. The second file has the Benton County conventional frequencies. Pressing 3 on the keypad will toggle the conventional system on and off. You will need to install the driver file for the scanner first. Save the attached zipped file to your computer and extract the 2 ARC-XT files. Open the extracted MO Hwy Patrol file with ARC-XT. Open the extracted Benton Co Conv file with ARC-XT. Go to the Scanner tab and click on Upload to Scanner. Check the boxes to select both systems. Check the box to Delete All Systems First (clears anything that may already be in scanner). Click on Send to Scanner. The PDF file will answer all of your questions about using quick keys. Quick keys as follows:
MO Hwy Patrol
SYSTEM QUICK KEYS:
1. MOSWIN Cole Camp (Site)
2. MOSWIN Warsaw700 (Site)
GROUP QUICK KEY:
*. MO Hwy Patrol
(Note: * = None)
SYSTEM QUICK KEY:
3. Benton Co Conv
GROUP QUICK KEYS:
1. BentCo Fire/EMS
2. BentCo Law
3. BentCo Pub Works
4. BentCo Schools
  • Benton Co MO XT.zip
  • Uniden Scanner Quick Key Instructions DMA.pdf
