Trackenv.txt
rhubbard
Bonnells Bay, NSW Australia
I'm Using Etrunker and attempting to suppress the audio for Patches. I've tried brilliant (not) things such as
SET TRACKPATCH=1
AND
SET TRACKF=1
Is it posssible to do this and how is it accomplished.
vktoo
BANDIT
Gainesville, Ga
Try just giving the patch id's a priority greater than the 50 threashold.
It will bypass audio for any priority greater than what ever you have your threashold set at.
rhubbard
Thanks, Bandit.
Yes, all my ID's are prioritized however, the system I am tracking has both analogue and digital capabilities. When an ID patches with a digital ID, or vice versa, it overides the SET TRACKDIGITAL=1 which is in my Trackenv.txt. There are only a few IDs which chose to go digital at this point in time and I would like to continue hearing the others just as long as I can. Eventually a sad day will come when this particular service group(s) will all be digital but until then, it would really help if I could eliminate hearing the annoying digital garbage from the patches.
Hope you can follow my line of thought, it is quite garbled.
BANDIT
Gainesville, Ga
If I am understanding you correct, you do not want to hear the digital comms. The SET TRACKDIGITAL=1 tells trunker to track the digital and encrypted comms. Take it out of your environment file.
D
DaveNF2G
Guest
Rather than removing the line, which leaves Trunker to decide what to do based on its own algorithms, it might be better to use SET TRACKDIGITAL=0, which gives it a definite instruction.
