- Joined
- Jan 5, 2003
- Messages
- 14,805
- Reaction score
- 10,758
- Location
- Retired 40 Year Firefighter NW Tenn
My post is from my experiences in Northern Mississippi, West Tennessee, West Kentucky, and Southern Illinois on the CN Tracks.
Can you please explain Entrance or exit message? ThanksOn the UP it depends on what type of DD it is whether it is ”talk freely”, which talks every train with an entrance and exit message, or “talk restricted “ , entrance message only , or “talk on defect only”, self explanatory. Most Hot Box detectors are ”talk restricted “, except for the ones near the yards which are “talk freely”. Stand alone dragging equipment detectors or wheel down detectors are almost always “ talk on defect only”.
Hope this helps with UP detectors.
Take care
Ed
You are welcome. The defect detector is set to frequency 160.455 talk on defect only is set to no. I just started getting back in to Rail Scanning after taking time away from the scanning hobby. I have 160.650 programmed but never hear anything on that channel. From what it shows on defect detector website that is belongs to the Albany district.It appears that the NS mainline running through Byron, GA is in the Norfolk Southern Brunswick District as this line runs northeast to Macon. You should be hearing the detector voice traffic on road channel 36/36 (160.650 MHz). Wasn't sure if you had this programmed, was not mentioned in previous comments.
See this RR reference: Georgia Railroads (Georgia) Scanner Frequencies and Radio Frequency Reference
220.7675 MHz is positive train control (PTC) telemetry. Thanks for mentioning this, going to do more research and listen when I travel. The FCC took the lower segment of the 220 ham band from us a while back. Heard that it was assigned to UPS, but this sheds more light on the rail industry communications.
This is what I hear in Central NC. "Norfolk Southern Milepost xx.x No Defects" twice.I am about 1.8Mi from the NS DD. It reports its MP location and "No defects" in two transmissions a few seconds apart.
This appears to be railroad specific, or even location specific; I can easily understand setting a detector to report on defects only in areas where there’s a lot of radio traffic (terminal areas, etc).I'm not offended, I just know that it's pretty common to have detectors that don't transmit voice communications for every movement over them.
Over here, NS has their detectors set for exit message only, while CSX has theirs set for both entrance and exit. In fact, CSX has revived the old Conrail practice of having the train crew answer the detector by giving train symbol, detector location and report (ie “CSX M205 milepost 110.1 no defects”).
...if a detector never transmitted by voice, how would you ever know it did or didn't exist?
Defect Detector Map
map.defectdetector.net
Sort of like the RadioReference database.That's far from an authoritative source as it is all crowdsourced and based on what information railfans can put together.
Okay, but nobody is trying to use the radioreference database to prove or disprove the existence of a system that doesn't transmit... And if they were, it would be as equally useless of a resource.Sort of like the RadioReference database.
@burner50
Do you have a better list?
