Were you there? Do you know the sight lines of the road to tracks? If so, please detail. Is it possible he entered before the signal and because he had people sitting on the bed such that he was going at a slow rate of speed? Is it possible he entered before the lights, and the gates came down onto the bed at which point he got stuck and didn't know what to do? I don't know these answers, and you don't either. Wait for the official ntsb report then judge if you must.
Sent from my cm_tenderloin using Xparent Cyan Tapatalk 2
While I was not there, I work there, and I know that crossing.
The track is tangent for several miles and the train can be seen for quite a distance.
The fact of the matter is, 99.9% of the time, the driver is at fault, The crew did everything right here, and everything was operating properly at the time, except for the stuff between the truck drivers ears.
The track is good for 70mph, and the crossing is inside a "quiet zone". The crossing is clearly marked along with big black and white signs that say "DO NOT STOP ON TRACKS".
20 seconds is the federal minimum, and it is plenty of warning. Remember, it is not intended as a warning to get off the tracks, it is intended as a warning not to foul the tracks. You're never supposed to stop on the tracks.
If the warning times were longer, it would likely increase crossing collisions due to the increased number of people driving around or under the gates.
You want to know the sad part?
The very next day, as news of this was sweeping the nation, I saw 12 people drive around the gates, and 5 more stop on the tracks for traffic.
You just can't fix stupid. You may get away with it thousands of times, but one time you're going to get bitten.
