TRBOnet users?
N1GTL
CT
Not "technically" a Motorola question but they are a "partner".
Does anyone have a TRBOnet system running that is locking up the dispatch console every so often?
I recently deployed a system using the Swift A200 gateways and like it much better than SmartPTT. The gateways are using both TRBO and non-TRBO radios. It seems that the consoles are hogging RAM until it is MAXed out at which point it starts lagging and the consoles need a reboot after which it works fine but eventually the same thing happens.
Trbogeek
Batavia, NY
Just saw this post. Not sure if you have found resolve to this, but we host a system, have 30+ consoles, 14 SwiftAgents, on it, and are not having this problem with the clients, but have seen this problem running the client on the server, for extended periods. Once we stopped running the client on the server, we have had no problems. What version and revision, are you running?
