Troop C Signal Strength
jeff
St. Augustine, FL
Has anyone noticed a drop off in the Troop C system signal strength in the western Burlington County area? Did they stop using the Berlin tower on the C system?
ampulman
South Jersey
I just checked. Signal is down 2 bars and has more static, but definitely readable (with rubber duck). Had gotten 3 - 4 bars prior.
No info in RR DB regarding site locations. Hope this is temporary. BTW, listening from Voorhees (RT 73 & Kresson Rd).
Do you know location of next nearest tower to you? Would likely be the same for me.
AM
jeff
St. Augustine, FL
The Bordentown site is barely readable in Medford, I've been monitoring C 3 Comm on the A system out of Berlin. I used to get both A & C with the same signal strength from Berlin, that's why I assuming the C system is no longer on the Berlin tower.
ctrabs74
California, PA
From RR and FCC database searches:
Troop A sites:
Atlantic City (WNHS409) - S Lincoln Pl between Boardwalk and Atlantic Av
Bass River Twp, Burlington County (WNDD579) - Radio Tower Rd off of Beaver Dam Rd (also Troop C site under a different callsign)
Berlin, Camden County (WNDD577) - NJ 73 north of the Berlin Circle (also Troop C site under a different callsign)
Bridgeton, Cumberland County (WNJI598) - NJ 77/CR 611
Camden City (WQDW595) - S 10 St and Newton Av (across from NJT bus garage)
Mullica Twp, Atlantic County (WPUH543) - Between US 30 and CR 561, west of Amotol Dr
Pilesgrove, Salem County (WNDD578) - US 40 west of Sharptown-Auburn RdWoodbine, Cape May County (WNII538) - Heilprin Av south of Ocean Dr
Troop B sites:
Franklin Twp, Hunterdon County (WNHS410) - CR 617 between Quakertown Rd and Lentine Dr (also Troop C site with same callsign)
Harmony Twp, Warren County (WNDD573) - CR 647 at Summerfield Rd
Jersey City (WPYQ725) - Washington Blvd @ Newport Center
Montague, Sussex County (WNDD572) - NJ 23 @ High Point State Park
Montclair State University (WNDD574) - Clove Rd
Randolph, Morris County (WNDD570) - W Hanover Av between Patty Ln and Lord Sterling Dr
Ringwood, Passaic County (WNXC890) - Skyline Dr @ Ramapo Mountain State Forest
Roxbury, Morris County (WNPS351) - Old Ledgewood Rd west of US 206 (in area of I-80/US 206 interchange)
Wallpack Twp, Sussex County (WNDD571) - "Hill 1606" - 4 miles east of Flatbrookville
Watchung, Somerset County (WQBY316) - Johnson Dr near Oakridge Ln
Troop C sites:
Bass River Twp, Burlington County (WQEG975) - Radio Tower Rd off of Beaver Dam Rd (also Troop A site under a different callsign)
Berlin, Camden County (WPSE858) - NJ 73 north of the Berlin Circle (also Troop A site under a different callsign)
Bordentown, Burlington County (WNDD576) - I-295 at US 130
Franklin Twp, Hunterdon County (WNHS410) - CR 617 between Quakertown Rd and Lentine Dr (also Troop B site with same callsign)
Holmdel, Monmouth County (WNDD575) - Garden State Arts Center (Garden State Pkwy at Exit 116)
Kingswood, Hunterdon County (WNXC891) - CR 519 Spur south of Tumble Falls Rd
Millstone, Monmouth County (WNZZ317) - Between Millstone Rd and Schoolhouse Rd, south of CR 524
Toms River (WNDD580) - NJ 37 and Tuyahov Blvd
ampulman
South Jersey
Troop B sites:
After reading the above, I programmed in Troop B, assuming that I could hear it from Voorhees (simulcasted on Berlin tower).
Apparently, if it was being carried, it has been dropped. Nothing.
Oh well, I'll keep it on my scanner for the occasional trip up north.
If I'm picking up Troop C from Bordentown, then I'm truly surprised as I can barely pick up Burlington Cty from the Medford tower. Mt. Laurel comes in a little bit stronger.
AM
ctrabs74
California, PA
Apparently, if it was being carried, it has been dropped. Nothing. Oh well, I'll keep it on my scanner for the occasional trip up north.
Troop B? I doubt you'd be able to get Troop B (North Jersey) from Camden County. Then again, I thought my eyes were playing tricks on me when I was in Delaware County, Pa. (Upper Darby area) and thought my scanner hit on a Troop C TG.
Sounds like you're comparing the Bordentown tower from the NJSP system with the Medford tower off the Burlington County system. I would think that the NJSP signal would be significantly stronger than Burlington County's signals to begin with, but since I'm not an expert on South Jersey, I'll defer to someone who can explain that better.
ampulman
South Jersey
__________________
Creighton Rabs
You're right. My assumption was that all 3 troops were being simulcasted on all of the towers.
AM
