jim holcomb
To all:
Unable to connect with BCD396T and I get an error message: Software has not detected your scanner. However, in the Virtual Control mode from the same PC, I can turn [HOLD] and [SCAN] on/off (some connection is present). I am using the ARC396Pro for Uniden396T V2.1001 PRO (2007); Full version and Win7 Professional. I did successfully connect with a different PC, but this (same OS) doesn't work?
I have tried resetting (regedit) Com ports in PC --- no difference. I tried new cable direct from 396T to USB --- no difference. I hard reset the 396T --- no difference.
Is there another solution around that someone knows about?
-Jim H
To all:
-Jim H
