I'm a ham op and just recently obtained my GMRS license. I picked up four cheap handies: Tidradio H3 and H8, Baofeng UV-21 Pro v2 and GM-T8. I configured all four with local repeaters and their tones. There is one repeater that works perfectly on both Baofengs and not the Tidradios. With the H3/H8 the display turns on when RX and I see the signal, but nothing comes out the speaker. I press monitor and I can hear the conversation just fine. OK figure it is the squelch so I drop it to zero and still cannot hear anything (Baofengs are set to 3). I cannot figure out what is wrong. I even went as far as to write down each menu item and their individual settings on paper to compare. Same RX/TX freq., same D125N for both on all four radios. It isn't a weak signal that one picks up better than another, as the repeater is 3 miles from me and using the same external antenna. I can hear the repeater ID every time on all radios. Freq/Tones given to me by Owner so should be correct (especially since it works on 2 of 4 radios)
At a loss here.
At a loss here.
