Trouble Programing Trunking OnA Pro 433
highrider8433
The problem that I'm having is when i get to the step where you enter the frequency I Pro 9 f on the readout and I can't go any further.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
That sounds like a talkgroup ID. First you must program the frequencies for the system, then the talkgroups (I could be wrong, but I don't think the 433 has the ability to show alpha tags along with the talkgroup). Of course it would help if we knew which system you were programming. The URL would be most helpful.
73s Mike
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
What county in Oklahoma? You can look that up in the database, and simply copy/paste the URL - that way others can see exactly the same thing you do. Just click on 'database' in the top blue toolbar, select Oklahoma then select the correct county.
73s Mike
mancow
N.E. Kansas
At Pro 9 F
enter the first control channel frequency then hit enter.
If you had previously selected a Motorola system before getting to the Pro 9 F field then it should show a small M next to TRUNK after you hit enter.
use the UP arrow key to go to the next channel
repeat the above steps
then hit search (if you have no IDs stored)
highrider8433
It won't let me enter a frequency when I hit search and it goes back to scaning the conventional things that I have pri gramed in to it.
highrider8433
Is there anyone in the OKC or Norman metro areas that can help me with the trunking on this scanner?
highrider8433
I would love to come to the meeting. However ther is problemthere also and that is that I am leagally blind and can't and don't drive.
mam1081
Next to a scanner...
Do you have anyone that can bring you?? We meet once a month usually - so even if you can't make it this time, we'll be here next month.
plaws
E Hawkesbury Twp, ON
I bet you'd drive better than some folks who have licenses.
Which town do you live in? Maybe someone can give you a ride.
