Hi everyone,
I’ve been experimenting with a DHT22 temperature and humidity sensor for a small indoor climate monitoring setup, but I’m noticing some inconsistencies in readings and would love some input from others who’ve worked with these sensors before.
Setup Details:
I’d love to make this setup stable before expanding it into a multi-room environmental monitoring system.
Setup Details:
- Arduino Uno
- DHT22 sensor (3-pin version) connected to digital pin 7
- 10kΩ pull-up resistor between VCC and data line
- 5V regulated power supply
- Data logged to an SD card module and displayed on a 0.96" OLED
- Testing indoors under stable room temperature and humidity
- Temperature readings vary by ±1.5°C between consecutive measurements even in a stable environment.
- Humidity values fluctuate more than expected (sometimes ±4–5%).
- Occasionally, the DHT22 fails to return valid data (“NaN” or checksum errors).
- Readings seem slightly delayed or laggy when compared to a commercial hygrometer.
- Added decoupling capacitors (100nF + 10µF) near the sensor’s power pins.
- Verified wiring and data pin pull-up resistance.
- Tried both the Adafruit DHT library and the DHTesp library — similar behavior.
- Placed the sensor in a small ventilated enclosure to reduce airflow effects.
- Tested with two different DHT22 units to rule out sensor damage.
- Is this level of fluctuation typical for DHT22 sensors, or should I expect tighter accuracy?
- Would adding time-based averaging or exponential smoothing help stabilize readings?
- How sensitive is the DHT22 to power supply noise — would a separate regulator help?
- Are there better alternatives (like SHT31, BME280, or AHT20) for more reliable temperature/humidity data?
- Any tips for improving long-term stability when the sensor runs continuously indoors?
