Ok, Updating this. I got stuck in the CPU firmware update mode.... For some reason I can't do anything via the two programs listed or even get out of this mode. Does anyone have any ideas?
I was using the GRE PSR500 CPU Firmware Upgrade Instructions v2.1.pdf to preform this update.
The confusing part is I hadn't tried to update any firmware till recently after I had encountered the issue. The only the only thing I can come up with is I held down tje PROG button while turming the scanner on and it stuck. Now it won't even allow for an update or anything else. As soon as I turn it on it starts in the CPU update mode. Guess I'll have to contact whistler on monday.
do a complete wipe out on the scanner reformat /reset it will go back to what was in it when you got the scanner.... so save whatever scanners file you may have.
