Trunk Mount?
jerneedog
St. Charles, MO
Would a Trunk Mount work on the hood of a truck like in this pic of
I_10_92's Truck, that was posted awhile back?
I'm wanting to do a similar setup with an Antenex ABSCANC antenna for use
with my hand held scanner.
Al42
Long Island, NY, USA
If you do a little metal work to it. Trunk mounts are designed to mount on flat trunk lids - that hood looks pretty round. You'd need a trunk mount with enough metal that you could bend it into the inside curve of the hood. Other than that, and the need to feed the coax through the firewall, you shouldn't have any problem.
JohnWayne
Lynchburg, VA
kb2vxa
Banned
Point Pleasant Beach, N.J.
Hi guys,
A HOOD mount? Ask yourself if you want to put up with all that engine noise, then reconsider. Unless you bond the hood to the body with heavy flexible straps it makes a very good antenna in itself and bonding is no guarantee it still won't act as an antenna on some frequencies. (resonance)
BTW, trunk lids also should be bonded but at the opposite end of the vehicle it's done for RF considerations when antennas are mounted there, not noise. In any case the hood should be bonded to reduce noise re-radiation.
rescue161
KE4FHH
Hubert, NC
The mounts that Jeff is talking about do not mount to the trunk lid or the hood, they mount to the body of the car under the trunk/hood lid, so there is no need to run a grounding strap from the trunk/hood lid to the body.
I've used these mounts too many times to mention on both hood and trunk applications with no noise problems at all.
I think what kb2vxa is referring to is the type that uses set screws to mount to the lid itself. Kind of like the old K-40 CB antennas. I have never used these. To me it looks like they put a crazy bend in the coax and that can't be good.
cdenton
Wyoming MI
K-40 trunk lid mount
I just bought a brand-new K-40 CB antenna, and it came with that very lid mount with the severe 90 + degree bend.
Seems to work well, though.
A lot better than the Rat Shack magnet mount I was using, anyway.
Sounds like I might want to look into those grounding straps ... the hood hinges mount to the body, though, don't they?
K5MAR
Stillwater, OK
I've got the "L" bracket (with a Larsen 150/450 dualband antenna) mounted on the LF fender of my '98 Chev. pickup near the windshield. I use it for a variety of radios, from an inexpensive RS SAME Alert wx radio to various handheld and mobile ham and commercial radios. I have NO problem with engine noise, nada, zip.
Mark S.
