avster
I am trying to work out what type of system the following is:
Licence Number 39967 Access ID 10260
Client Amatek Limited
Site Captain Cook Drive KURNELL
Operating Mode Transmit/Receive
Frequencies Assigned 469.5750000 MHz Lower 469.5625000 MHz
Carrier Upper 469.5875000 MHz
Device and Antenna details
Device ID 39869 Emission Designator 16K0F3E
EIRP 0 Transmitter Power 5.00 pY
Antenna ID 71
Antenna Height (AGL) 0 Antenna Polarity Vertical
Antenna Azimuth Antenna Tilt
Licence Number 39968 Access ID 10261
Site Wilberforce Rd WINDSOR
Device ID 39510 Emission Designator 16K0F3E
Antenna ID 71
Motorola radio's used in the system yet to be identified, will be checked out in a few weeks.
The system operates as follows:
each radio has a 2 digit ID,
a caller has to enter an ID of the radio it's calling via the key pad on the radio, then key the mic s/w on the mic and the radio calls the other radio. The radio recieving the call presses the mic s/w to answer and a private 2 way conversation can be made.
I don't know if a radio can talk to all users at once like on a conventional radio network.
Antenna ID 71
Antenna ID 71
