Trunking Change?
K0MSM
Dana, IA
Hi all -
I've noticed over the past week or so that I'm not getting near as much traffic on Suscomm. In fact, right now, I'm hearing nothing - and usually DSP is very chatty during the day. I can still get Fire/EMS on the 453.225 simulcast, but not hearing anything on the 800 talkgroups that correspond. Did they change up some of their trunking frequencies? Anyone know?
Sean
EdwinAnthony
Lewes, Delaware
SusCom in Sussex County
Same here! I've been checking the Frequency Databases on a daily basis for a control channel change for Suscom in the State of Delaware.
troymail
Silent Key
Just checked the licenses - there appear to be 15 frequencies on the license but only 10 listed on RR.
See if adding these help:
851.01250
851.51250
852.01250
852.51250
853.01250
wtp
Port Charlotte FL
some of them
are the 8tac channels and would not be used for trunking.
some add the 853.5125 but i believe that has no designation.
why not try and scan the band ?
ecps92
Taxachusetts
Those are the 5 Nationwide Interops and would not be part of the Trunk
They are Conventional Repeaters/Simplex
851.01250
851.51250
852.01250
852.51250
853.01250
troymail
Silent Key
Doh! :eek: I thought they looked familiar..silly me. I'm used to seeing them in Maryland on separate licenses.
Yes - I agree - time to use the search function.
LeSueurC
Virginia Beach, VA
If you're using a Uniden scanner, I noticed sometimes the Dispatcher either hits the Encrypt button or leave it from Data or a Tac channel. The scanner won't pick up as much if this is the case.
troymail
Silent Key
A suggestion - I believe the sites are connected and if you can pick up the Kent site and have access/ability to feed the Kent CC to Pro96Com, it should tell you the CC frequency for the Sussex site.
Just a thought.
de784
Delaware
suscom
Seems like they have been other frequencies other than the control I programed all frequencies in and seem to work.Started about three weeks ago
GKibby
Trunkong Change?
Same problem. Worked fine until 2 days ago. I haven't heard a thing on either of my state police scanners since. All the fire groups still work normally. I was hoping it was only a maintenance problem.
K0MSM
Dana, IA
Ran a search this morning - found a new control channel at 853.1125.
GKibby
Susscom
Susscom just came back uo on all their old talkgroups. Whatever it was seems to be fixed.
GKibby
Susscom
Well, that didn't last long. Susscom was back up on their talkgroups but I have heard anything for a while. Maybe that's progr
de784
Delaware
program all tower frequencies in they seem to be using different control channels at different times
