Trunking Question
BaLa
4GRC+83; Temple, TX 76502
I work at a factory, we use radio communications
I believe we use a trunked system (99% sure)
I have a list of frequencies, but I don't know what the Control Channel is.
Is there any way I can find that out?.
I also do not know what type of Trunked system it is, anyway I can find that out for sure as well?..
I have a Pro 95 scanner
bnglbill
Delaware (New Castle County)
I dont know if this is the easiest way or not but one way to find out the control channel is to program them all in as conventional and the one that makes all of the wierd noises with no communications on it will be the control channel.
W4KRR
Coconut Creek
It they use an LTR system, there won't be any control channel. If it's LTR, there may be a very short burst of noise on the frequency every 10 seconds or so, but not all LTR systems will do this.
DJ88
Brick Twp., New Jersey
Are the frequencies in the 400MhZ, 500MhZ, 800MhZ or 900MhZ range ? If you could let us know, maybe we can narrow down the possibilities as to the type to see if you even need to program a control channel.
DJ88
I am by no means an expert on trunked systems, but it looks like the system MIGHT be a Motorola Type 2 Smartnet. It would get programmed into your scanner as a Motorola Type 2 UHF. However you will need the Base Frequency, Offset Channel and Spacing in order to program it. There may be a way to determine what they are, but I am not familiar with it.
If you get no further responses here, you may want to post another question asking if anyone knows how you can do this. The question may have already been asked here before, I don't know. I went through a bunch of posts trying to find it for you, but didn't see anything. There are a lot of people on this board who know a ton about programming trunked systems into a scanner. I am sure someone would be able to help you.
Good Luck
Ken
