Trunking Recorder v3.5.5675+Proscan
Muxlow
Super Secret
Middlesex County
Iv got Proscan all setup like it shows in the instructions and its seeing activity and recording audio and saving that into the proscan recording folder
Trunking recorder is setup how the instructions say and iv entered my API key and system ID/Node ID for the Call Ingest Nodes
I see nothing happening in the TR window other then it says recording is started and in the bottom left shows Proscan importing - uploading started
If i open the VIEW RECORDINGS tab i can play back all the audio files and what not so i guess TR is getting audio from proscan but im seeing nothing on the brodcastify site. Says the node has not been seen at all
Am i missing a step here? Everything looks exactly how it does in the photos for setting up proscan and seems to half ass be working just not sending the info to BCFY
W2NTV
Union vale NY
did you click the record button???
dave3825
Suffolk County NY
What scanner are you using?
Generally, you won't see anything other than that,
unless TR was off for a while in which case it will show how many its imported out of the total amount sitting in the folder.
Muxlow
Super Secret
Middlesex County
SDS200
Its sending the audio for my RR feed just fine so figured id add the call injest option too but cant seem to get that working. My call feed has been removed since it hasnt sent any data to the server so guess this is a moot subject now
