TrunkView 2.0/BCD396T Incompatibilty
subclavius
You'll see a similar post in the Uniden section. I apologize for the cross-post, but I'm desperately looking for a fix for my scanner, and I also feel I should warn anyone with a 396 who is thinking of trying TrunkView 2.00.
Long story short, after running the band scan feature on TrunkView 2.0, my 396 now drops ANY signal every two seconds, for the duration of about half a second. This seems to be the interval the TrunkView band scan was controlling the receiver with, but now my 396 drops the signal every two seconds even when TrunkView is not being used.
Reloading the Uniden firmware and previous configuration hasn't fixed the problem. Now I'm off to the TV Yahoo group to see if they can help. Unless there's something I'm overlooking, I would STRONGLY recommend anyone with a Uniden 396T to stay away from TrunkView 2.00.
subclavius
I fixed the problem by reseting the scanner's memory. I think I'll lay off the MPT1327 stuff for a while................
Saint
Fort Erie Ontario Canada
Mpt1327
:cool: Use Unitrunker for decoding MPT1327, it works perfect.
Steve
D
DaveNF2G
Guest
So you've posted two separate threads slamming a piece of software that is not at fault in your problem. Nice.
morfis
Steve
It might work reasonably well but Trunkview has a whole host of features that Unitrunker doesn't. I like Unitrunker for Motorola systems.
As for the original post.......I've been running TV with a 396T since the beta control for it was introduced and have had no problems with the radio.
UPMan
In Memoriam
Arlington, TX
If audio was dropping every 2 seconds then either Close Call or Priority got turned on. Likely has nothing to do with the software (unless the software sent an erroneous command to turn on the feature).
morfis
UPMan said:
If audio was dropping every 2 seconds then either Close Call or Priority got turned on. Likely han nothing to do with the software (unless the software sent an erroneous command to turn on the feature).
Trunkview initiates and starts a quicksearch - it does nothing to Close Call or Priority settings.
Napalm
Calls provider
Lake Co, Ind
Just to add to what Morfis said...
With a scanner that has a "front panel" and controls, there's no need to use Trunkview's Bandscan feature. Might as well initiate your own search from the controls on the radio - the radio's own search is much faster than TV anyway.
FYI's, I just ran the Bandscan from trunkview on my BCT-15 and neither CC nor Priority were enabled after I came out of the scan.
I'd politely suggest it was user error in this case.
Those were my thoughts too.
TV most definitely does. UniTrunker provides basic decoding. Having the program control the radio that provides the control data so that the software knows the exact frequency of the current control channel would allow any program to do a better job of distinguishing two or more systems programmed with the same system ID - a common problem with MPT1327 systems. On of these days I'll get around to that.
morfis
Unitrunker said:
..... allow any program to do a better job of distinguishing two or more systems programmed with the same system ID - a common problem with MPT1327 systems. On of these days I'll get around to that.
Is this a common problem in the US? My experience around Europe and the East has been otherwise.
I'll look forward to the Unitrunker version that incluses the features from TrunkView/PTrunk/Trunksniffer Pro and therefore to be able to use it exclusively ;)
morfis
Unitrunker said:
Must be. Lots of 2309 and/or 2319 system ids.
In the same radio area?
System Idents are re-used but not usually within the same geographical proximity.
Life would be easier if the sysid was allocated centrally like the Motorola ones - though I have never come across two systems with the same ID causing each other problems (limited monitoring of civvy stuff in the USA)
morfis
Jay said:
Yes; I described this back when I was using TV. 3 systems in my area (were) using 2319.
Have you tried monitoring them with the most recent version of TV? It allows you to have multiple sites with the same ID but differing profiles and select the relevent one when monitoring.
(probably ought to be a separate thread now)
pyeman99
Redruth UK
I'm using TV 2 ,no problem with 396 in UK works quite normally.
Set up as UP Man says.
Regards Keith.
