TRX-1 Display
murf613
I have a trx-1 and while scanning all the scanlists scroll in the display while scanning, Is there anything I can do
to change this, Thanks
pgates
Bryan, TX
Hello. I believe that is default (and, maybe, immutable) behavior for both the TRX-1 and TRX-2. There are only so many lines available on the display so, if you have more than five scanlists enabled, they scroll by so that you can eventually see all of them that are enabled.
--Phil
tvengr
Well Known Member
Baltimore County, MD
My WS1080 has only 5 lines available to display scan lists. If you have 5 or fewer scan lists enabled, they will remain stationary on the screen. If more than 5, the scan lists will scroll to display all scan lists enabled.
JD21960
ILL-annoyed
If you mean the lines scan? that's default behavior. But if you have ALL them scanning? even the ones you don't want? Yes. You can LIMIT the number of scanlists on the 1st TAB in EZSCAN (GENERAL) and also in the (Advanced TAB) you can limit it or expand in your SCANSET 01. *the default Scanset is ALL the lists 0-however many there are. Notice how I limited my Scanlists to 31 *plus Skywarn and #200 in the photo on the Advanced TAB. On the first TAB (GENERAL) in EZSCAN ... there is where you can turn on or off all the LISTS that are scanned *or seen scanning* My other photo shows I stopped at 31 lists. When set the way you want? you upload that data to the scanner. You can also try to do this manually on the scanner, though it takes a long time
