Welcome to RR!
I have a TRX-1 and it works great with our county's new P25 Phase 2 system, except when we're out and about. Sitting still, it works great. When we're out, I use my SDS scanners.
I also read a trick that someone posted quite a while ago, where you create a dummy site, so that you can adjust the Data Decode Thresholds.
I have been listening to this system on my Unication G5 with excellent results, but in the last couple of days I got around to adding that system to my Psr800 factory updated to a WS1080. The audio just seems to catch parts of words and syllables on that system. Any others that have tried that...
forums.radioreference.com
I tried it and it works very well. It doesn't 100% solve the simulcast distortion issue, but it is much better.
The other thing I learned with these simulcast systems, is that less antenna is more. I use either my Comet CH-32 or my Diamond RH3 antenna. I've heard of people using paper clips. Whatever works...
We can fiddle with this other stuff, once we get you rolling.
I'm assuming that you want to listen to this system:
Franklin County VHF Trunking System Profile
www.radioreference.com
And everything but the Public Works talkgroup.
I put something together for you to try if you want. It's basically the Franklin County VHF system broken down into four scanlists and a fifth scanlist for the analog channels.
Two Scan Sets, one active for the county VHF system and another which you can activate if you wish, with the analog channels.
For the VHF system, I used the Library Import, "Preferred", "County", "Trunked Systems"
This way you can compare what I put together against yours and/or add my CDAT to your radio to try it out.
Please let us know how you make out and if you have any more questions, we're here for you.
