Version 3.44 - August 11, 2022 |
- Fixed an issue when copying LDB files to the scanner's SD Card where the files were being placed in the incorrect folder and then copying more than the LDB files to the SD card
Broke the location data base Again. scanlists 151 through 181 all 0's again. Thank You
I had the same happen to me when updating from 3.43 to 3.44 through EZ Scan. Download 3.44 directly from the Whistler site. Uninstall 3.43 and install 3.44 from the downloaded file.My Scanlists 151 through 181 all 0's again after update!
Sorry, I will look into this again
Hi
Current version 344.bld.699 still have the scanlists above 151 are still showing 0 thanks
no fix for the scanlist issues ? seems like its been a while
Is the WS 1098 DMR update still in the works?It coming, just need to finish testing before release.
Didn't you get an update for a DMR fix for the TRX series?Not sure what your question is exactly, the WS1098 supports DMR, however does not do true trunking on DMR systems.
