Trx2 phase 2 tdma programming
vocoder
Indiana
What scanner only (not EZ) programming steps have to be taken to input a phase2 tdma system on trx?
I programmed as p25, but it does not work, it seems to try though, with wildcard. It stops on tg but no vocal.
I do not see choice for tdma.
troymail
Silent Key
P25 is programmed the same way regardless of Phase 1 or Phase 2.
The situation you are describing (stops on talkgroup but no audio) is a strong indication of well known and discussed simulcast reception problems.
