BCD325P2/BCD996P2: trying to scan loaded frequencies
onetimephil
It says scanner must be communicating. What does that mean.. I have the two hooked up with the cable.
ProScan
Software Provider
Ontario, Calif.
Does the ProScan display show like the scanner display?
{edit} It means the scanner is not communicating with ProScan.
ProScan
Software Provider
Ontario, Calif.
yes it has a picture of my scanner on the screen.
{edit} Not just a picture but the display is the same as the scanner.
To make sure it's communication and the display is current press the Menu key on the ProScan virtual panel and see if the display changes in ProScan.
ProScan
Software Provider
Ontario, Calif.
Go to the ProScan Comm Port menu then click on Auto Detect. If the port shows "In use By This Instance" then set the port to None then try the Auto Detect again. Does the scanner show in the Scanner column? If yes then click Set then try the download again.
If no then that needs to be fixed.
Go to the Win Device Manager and see if the Serial Port is working
Did you install the driver? The link below contains another link to the driver. The same driver works with the BCD996P2
Is the cable plugged into the front or rear scanner port?
onetimephil
I've got to go. I'll just leave it where it is for now. I'm not getting anywhere. Thanks,Phil
ProScan
Software Provider
Ontario, Calif.
When you get back. Power cycle the scanner and check the Win Device Manager that there's no yellow exclamation point indicating an issue.
JoeBearcat
Uniden Representative
Sounds like you have a Trunking System set up as conventional.
What type is it DMR NXDN P25
You need to set LCN for each channel
Either that or they have a data talkgroup active. But your thought was my first one, too.
ProScan
Software Provider
Ontario, Calif.
onetimephil
I'll try that again. I'll have to get the scanner and the computer hooked up again. Might be awhile. Thanks
