TSA?
Steve08CVPI
Are these correct? I never hear anything
djeplett
NE Wisconsin
Two things... Since its the US Government it's probably encrypted. And how close are you to the airport? You might need to be very close.
ecps92
Taxachusetts
No - Not Correct. Years ago the TSA moved to a unique NAC per Airport and ceased the common uses of $001, $002, $003
That said, remove the NAC from your programming and if around the airport [the system was engineering for On-Site coverage, so don't expect much distance from it] see what you get.
some airport have moved off 172.9000 to other channels, and there is a nationwide move [altho very slow] to go UHF [which will even more decrease the distance heard from the airport]
As to ENC, it is selectable per radio and the use will vary by User, Airport, Time of Day and any security issues/Operational Tempo as determined by the User, Airport or their Supervisors.
Tim
Milwaukee, Wi
Greetings...
I use to live about 2 miles west of KMKE airport and if the weather was right, I could pick them up. The few times that I did actually hear them using the radio, it sounded like 'simplex' to me.
OpSec
All your WACN are belong to us
Monitoring the database
There used to be a TSA repeater in New Berlin.
May be worth sniffing around the NTIA subband to see if it still lights up, but I don't listen to fed traffic since it's 99.9% encrypted.
rjschilder
AES FTW
Can't you just use NAC $7FE?
ecps92
Taxachusetts
That feature works with a REAL Two-way radio, but not a Scanner.
Yes you can listen without the NAC, but then you also could [YYMV] have to deal with near-by [dueling] airports of other users on the same Freq.
ie: I have a VA Hosp that is on the same freq as one of the CBP Air-x channels.
And we also have ICE authorized for a Repeater on the ole 172.9000 TSA [former FAA] channels - with a unique NAC
And having the NAC is many time a Confirmation of who it is.
wtp
Port Charlotte FL
i used to work near Punta Gorda airport in Florida.
i used a uniden 396T and had all the TSA freqs in it.
if i was inside our building, i could not hear them.
outside was spotty at best.
i was across the street and around 1000 FEET away.
so you would want to be closer, to hear handhelds, than that.
when parked in the parking lot i got more transmissions.
LDRA37
SE WI
The move to UHF has happened in WI.
ecps92
Taxachusetts
Which Airport in WI ?
and of course what Freq and NAC ??? are being heard
I've only heard of Two Airport having migrated over the Fall/Winter
and those were Boston and Colorado Springs
wirr
Senior Member
406.1125 DMR active at or near MKE.
CrabbyMilton
If it's in the clear, I too would have to guess that it's the USPS. They have that monster sized facility just to the southeast of the airport now.
