radioman253
My PSR 500 is great, but the TUNE mode is a pain on some freq ranges.
An example of this is the 138 to 144Mhz range that the Ontario Bell Fleetnet system operates on.
With Flex-step turned on in settings menu, I can press the Pause button and manually tune to for example 142.110Mhz but when a signal is present, TUNE mode will only stop on
142.1125Mhz.
This is a big pain as I miss half of the action on various bands that I am searching.
The 420Mhz range is also a problem,but this time because the signals I am trying monitor
use 12.5Khz spacing but the radio will stop on for example 420.490 when I it should have stopped on 420.4875.
Is there a setting for the TUNE mode in the Func/Glob settings that would cure this???
Any one else having this problem?
fYI : I am using the latest firmware..
142.1125Mhz.
