riverrat373
What's the difference between a SWL tuner and a preselector?
There's a lot more to it than that - read the article and you'll understand better...Mike
If the transmatch is at the station position, it will attempt to tune the antenna and, if the antenna uses this, the feedline as well. A classic example of this is an inverted L, where the feedline is part of the antenna.
Transmatches can help with antennas that don't work well on a particular band, just for a listening application (hams have a number of other things they can be used for). Personally speaking, you're better off fooling around with a different antenna, if you had the space for it.
Mike
