Turbo Connect TIII
mbstone99
Hamilton, Ontario
In Vaughan today, this is what I saw:
420.5875 TIIInonstd MOT Site L6-10 DCC 6 RAS NL 3 9 11
420.8125 TIIInonstd MOT Site L12-10 DCC 10 RAS NL 3 11 12 13 14 9
Super weak and so could be a bad decode:
420.1750 TIIInonstd MOT Site L1-5 DCC 0 RAS NL 1 2 3 6
420.1750 is Talk Wireless' T3 site in Milton.
Matt
mciupa
Canadian DB Admin
Moderator
I'm here a lot
420.5875 = MRC System - Brisbane site
420.8125 = Turbo Connect - Milton site
420.1750 = see above post
VA3ADP
Mississauga, Ontario Canada
I've been monitoring Toronto the last few days and have not stumbled across any OTA Aliases. Did the techs maybe disable them? I seem to have talker aliases set up correctly on DSD+
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
You need to make sure you are in trunk tracking mode and thus tracking all voice calls, including encrypted voice following. If you are just parked on the control channel, you’re not going to get talker aliases, and if you don’t have encrypted voice call following enabled and everything’s encrypted you’re not going to get the talker aliases either.
VA3ADP
I'll have to review my settings later on and advise.
Muxlow
Super Secret
Middlesex County
That 407 group is still coming over the Windsor site and I'm seeing all their alias come over. If you don't have the Combine CC/VC Monitor checked and have the frequencies in your frequency file so it can track them.
Plus have Control-Voice/Data Call Following-Full Following and Encrypted Voice Call Following-Full Following
Once all that's good you should start to see them. They get decoded over the voice channel not the control
Just looking at my log and I see another group in the same range as the 407.
9803
You guys seeing that out your way also?
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Just looking at my log and i see another group in the same range as the 407.
9803
Nope. Slim pickin's my way.
Only:
TIIInonStd,L12, 9802, 50, Normal, 225, 2025/10/15 8:06, ""
TIIInonStd,L12, 500001, 50, Normal, 6, 2025/10/05 16:34, ""
and with these radios:
TIIInonStd,L12, 9802, 4055, 50, Normal, 3, 2025/09/30 17:21, ""
TIIInonStd,L12, 9802, 9109, 50, Normal, 1, 2025/10/14 15:40, ""
TIIInonStd,L12, 9802, 9110, 50, Normal, 3, 2025/10/14 15:31, ""
TIIInonStd,L12, 9802, 9239, 50, Normal, 2, 2025/10/01 8:33, *"ETR 7-25"
TIIInonStd,L12, 9802, 9242, 50, Normal, 34, 2025/10/14 15:44, *"ETR 238-25"
TIIInonStd,L12, 9802, 9252, 50, Normal, 1, 2025/10/15 7:59, *"ETR 20-25"
TIIInonStd,L12, 9802, 9259, 50, Normal, 1, 2025/10/09 15:40, ""
TIIInonStd,L12, 9802, 9783, 50, Normal, 6, 2025/09/30 17:21, ""
TIIInonStd,L12, 9802, 9999, 50, Normal, 43, 2025/10/15 8:06, *"ETR 23S DISPATCH"
TIIInonStd,L12, 500001, 7206705, 50, Normal, 4, 2025/10/05 16:34, ""
My reliable towers are: Toronto, King City and Milton in order of signal strength.
Muxlow
Super Secret
Middlesex County
So the 407 ETR group is 9802 and Kelcom's group 500001
Maybe this 9803 one isn't part of the 407 stuff or they are doing testing at the Kelcom office before doing over the air programming or something. Whooooo knows?
Muxlow
Super Secret
Middlesex County
I heard some testing yesterday on group 510003, radio 510263-Mississauga P1
I'd take a guess some Mississauga area talkgroup. If any of you GTA peeps see that RID or group down your way.
VA3ADP
Was that clear or ENC? I know there are a few companies I've stumbled across on FleetConnect that are Mississauga based. Still quite a few users to migrate over to the CapMax
mciupa
Canadian DB Admin
Moderator
I'm here a lot
I was bouncing between Toronto, Milton and King City towers on TurboConnect this afternoon. The only activity was 407ETR off of King City.
No Mississauga aliases. I'll have to pour over files next.
mciupa
Canadian DB Admin
Moderator
I'm here a lot
On the Milton tower, I am getting some aliases with certain radios. I have matched RID 9999 with talkgroup 9802 and Steeles Dispatch or 23S. Talkgroup 9804 is Derry Dispatch, alias Derry WEB Dispatch on RID 9782. Not getting this on Toronto tower.
Muxlow
Super Secret
Middlesex County
I think the 9801-9804 groups are all the 407 ETR people. Don't know if they split it up for specific group for a specific section of the highways or if one group is for snow removal stuff and another for debris and crashes type thing
I've got on 9802
a bunch of ETR-numbers of vehicles and 9VXXXX
A couple MSO XXX
9018 - Control 01
9237 - Steels Form
9999 - Steels Dispatch
Group 9803
Bunch of the ETR-XXXX's and 9VXXXX
9020 - Control 3
9238 - Brock Form
9791 - Web Super
9994 - ETR Derry Disp
Group 9804
9782 - Web Derry Disp
Group 9806 (Perhaps maintenance group)
9231 - Available 17
9425 - Repair
VA3ADP
Noticed these two interesting Aliases on the 407 TG's earlier yesterday;
TIIInonStd,L12, 9804, 9726, 50, Normal, 2, 2025/11/28 12:51, *"9V2651"
TIIInonStd,L12, 9804, 9735, 50, Normal, 1, 2025/11/28 10:14, *"9V2670"
As for a TG 9801 that @Muxlow mentioned, I have not seen that appear as of yet.
mbstone99
Hamilton, Ontario
I've got on 9802
A couple MSO XXX
9018 - Control 01
9237 - Steels Form
Group 9803
9020 - Control 3
9238 - Brock Form
9791 - Web Super
Group 9804
9231 - Available 17
9425 - Repair
I also seen RID 9231 Available 17 on 9803
TG 9803 RID 9507 ELS DISP
TG 9805 RID 9206 WEB BROCK DISP
Matt
gary123
current 407 ETR groups for the system
TIIInonStd,L12, 4055, 50, Normal, 0, 0000/00/00 0:00, ""
TIIInonStd,L12, 9018, 50, Normal, 0, 0000/00/00 0:00, "407 ETR Control 1"
TIIInonStd,L12, 9019, 50, Normal, 0, 0000/00/00 0:00, "407 ETR Control 2"
TIIInonStd,L12, 9020, 50, Normal, 0, 0000/00/00 0:00, "407 ETR Control 3"
TIIInonStd,L12, 9109, 50, Normal, 0, 0000/00/00 0:00, ""
TIIInonStd,L12, 9110, 50, Normal, 0, 0000/00/00 0:00, ""
TIIInonStd,L12, 9231, 50, Normal, 0, 0000/00/00 0:00, "Available 17"
TIIInonStd,L12, 9237, 50, Normal, 0, 0000/00/00 0:00, "407 ETR Steeles Form"
TIIInonStd,L12, 9238, 50, Normal, 0, 0000/00/00 0:00, "407 ETR Brock Form"
TIIInonStd,L12, 9239, 50, Normal, 0, 0000/00/00 0:00, "407 ETR 7-25"
TIIInonStd,L12, 9242, 50, Normal, 0, 0000/00/00 0:00, "407 ETR 238-25"
TIIInonStd,L12, 9252, 50, Normal, 0, 0000/00/00 0:00, "407 ETR 20-25"
TIIInonStd,L12, 9259, 50, Normal, 0, 0000/00/00 0:00, ""
TIIInonStd,L12, 9425, 50, Normal, 0, 0000/00/00 0:00, "Repair"
TIIInonStd,L12, 9782, 50, Normal, 0, 0000/00/00 0:00, "407 ETR Web Derry Disp"
TIIInonStd,L12, 9783, 50, Normal, 0, 0000/00/00 0:00, ""
TIIInonStd,L12, 9791, 50, Normal, 0, 0000/00/00 0:00, "407 ETR Web Supervisors"
TIIInonStd,L12, 9802, 50, Normal, 0, 0000/00/00 0:00, "407 ETR Steeles Ops"
TIIInonStd,L12, 9803, 50, Normal, 0, 0000/00/00 0:00, "407 ETR"
TIIInonStd,L12, 9804, 50, Normal, 0, 0000/00/00 0:00, "407 ETR Derry Ops"
TIIInonStd,L12, 9805, 50, Normal, 0, 0000/00/00 0:00, "407 ETR"
TIIInonStd,L12, 9806, 50, Normal, 0, 0000/00/00 0:00, "407 ETR Maintainance"
TIIInonStd,L12, 9994, 50, Normal, 0, 0000/00/00 0:00, "407 Derry Disp"
TIIInonStd,L12, 9999, 50, Normal, 0, 0000/00/00 0:00, "ETR 23S Disp"
