Two Transceivers w/one KCH-20R - Bluetooth Programming Possible?
intermod
Unhinged Conspiracy Theorist
California
Is it possible to use BT to program a dual-deck with a KCH-20R? I have been unable to program this setup ever since I added the NX-5700 deck to the NX-5800/KCH20-R set. The "BT Interface Selection" is greyed out.
Also - the KPG software finds the BT devices from each radio, but when I try to write using Multi RF Deck Setup, KPG briefly talks to the selected indiv deck, then gives this error:
Both decks have the BT license, and I have enabled BT under "Product Information" for both. And even wrote the files back to the radios.
BT is enabled under the Control Head Menu function, and it can find local devices under "Find Devices"
Any other reason I cannot enable BT programming through the head?
KPG-D1N V5.10
KCH-20R: K 5.14.00
NX-5800 : K2 K 5.14.00
NX-5700 : K K 5.14.00
kd4efm
EL98 Florida
The Bluetooth programming is set via the product info. Your photos are for Bluetooth devices like an ear piece.
Both decks will need that check box in product info checked and uploaded to the radios then you can BTSPP.
Yes, you can, via Bluetooth program both decks, using D1 in Bluetooth mode.
intermod
California
Working now. I may have thought I wrote the file back into each deck, but the VHF deck showed otherwise. So, the solution was to perform a Read Configuration in the Radio Info dialog box, check the BT box (if unchecked; also assumes you have the BT license), and write the file back in.
Thanks for the help.
