TwoToneDetect71 Released
wscott
NJ
Already exists? It sounds like you inadvertently may have started the program twice and it is trying to save two copies of the same file. Or do you maybe have the same tone set in tones.cfg twice?
It looks like it is only open once. I rebooted the computer and reopened the program. I’ll keep an eye on it and see if it happens again.
DC31
Massachusetts
ff1520
Platte, SD
Does anyone know what the MMS and SMS gateway addresses are for FirstNet? Did some google searching as was unable to find anything. Don't have a FirstNet device close to test and find out. Would appreciate any info you might have.
Thank You
xxbryantd
Thank You
Use the att gateway
DC31
Massachusetts
Thank You
You have two choices :
@mms.att.net
@mms.firstnet-mail.com
Or @txt.firstnet-mail.com for SMS, i think
Both seem to work equally well
prolistener
Anyone know what’s going on with the two tone detect download page? It’s been down for many weeks now....
w9iku
I am using the current version. My issue is that I am not getting an email with an audio attachment if two separate departments (FD and Ambulance) are toned at the same time. I get the initial text notification for each department but I do not get the audio email after the page is complete. I get an audio email if only one of the two departments is paged. Any suggestions?
aaknitt
Can you confirm whether the audio files that you're receiving when a single department is paged are in MP3 or AMR format (as opposed to WAV format)? I'm wondering if this is caused by missing or incorrect ffmpeg installation and lack of MP3 file creation.
Andy
w9iku
Andy
The attached files are in WAV format for the individual page outs.
w9iku
And I now have FFMPEG.exe in the right directory since I opened the debugger version of the program and noticed the exe file was not found.
aaknitt
So even after getting ffmpeg.exe into the same directory as TTD you're still only getting WAV files? In that case it may be the wrong version of ffmpeg. Any errors in the debug output?
Andy
w9iku
Andy
I have not had any tones for the two departments in question since I corrected the ffmpeg issue. I did get a single tone out for another department and that did convert to MP3 after the fix. So no more WAV files, I believe. That part of the issue (if it was part of it) is now resolved. When the FD/Ambulance gets the next simultaneous page/call, I will post the results either way. Thank you for working with me on this.
aaknitt
Ok sounds good. I think that'll fix it for you. If not, let me know.
Andy
w9iku
Andy
Andy, Thank you. That resolved the issue. I now get the two files when they tone out at the same time. I misread the instructions and installed the FFMPEG folder in the directory, not the exe file.
Thanks again!
prolistener
Any news as for when new accounts for audio hosting to TTD will be available?
jkeyze01
Anyone else experiencing TTD hanging and when relaunching chrome just hangs. If I launch headless by adjusting the config it still won't load the management page. Windows shows that its listening on the correct port. I have to reboot Windows to get it launching again. Just curious of others have seen this?
KD2HKB
Sherburne, NY
Out of curiosity (before I work on starting my deployment of TTD), is there any limitation on how many tones can be defined in TTD? Meaning... I'm wanting to monitor and have it trigger for all tones in my area, eventually covering two counties, to be used as an "offline log" of sorts of emergency dispatches. I haven't looked through everything yet, but this would involve over 50 sets of tones.
