TxWarn - Beaumont Site
teebee
Lake Charles, LA
Can anyone confirm if the two CC's listed in the DB for TxWarn Beaumont Site are correct. I have both of them programmed and have no data or any transmissions from that site. Totally dead. This is leaving me to think these are incorrect or the site is not active
SA_tx_88116
Rather listen than stream
Cibolo, Texas
There could be several reasons why you aren’t receiving data, you either didn’t program it as a trunked system, maybe you don’t have any talkgroups programmed, or maybe those sites aren’t correct. Also what radio are you using.
teebee
Lake Charles, LA
I have the complete TxWarn system programmed and have no issues picking up several other Sites in the area. Anahuac, Ames, Santa Fe to name a couple I can hear. Its just something about the Beaumont Site I cannot get.
SA_tx_88116
Cibolo, Texas
Well in that case I can’t help because I live in San Antonio and I am not familiar with TxWARN and if you can hear talkgroups just fine through those other sites then you should use the one closest to you unless told otherwise.
rattlerbb01
TX/LA Database Admin
Boerne, Texas
Are the Control Channels listed in the DB up to date and correct? I at least want to make sure I have the correct CC's programed
They are only as up to date as users have reported. I would suggest scanning the 769-775 MHz range nearby the tower and seeing if a control channel comes up on a different frequency. We don’t get automatic updates from the system admins, local governments or any agencies. Everything is submitted from listeners and occasional users.
giant22000
I can confirm they are correct as I hear Cambers Co on that site sometimes. I live in Beaumont so I’m in close proximity to the site.
