Tytera TYT MD 9000 woes
bobruzzo
W1AV
Cranston, Rhode Island
Hello
I purchased a TYT MD 9000 a couple of months ago cause I wanted access to a few local 220 repeaters and also for ragchewing with local hams on simplex. The radio is an analog 220. One problem is no matter what I have tried I cannot get the radio to scan. Does anyone with this radio have same issue? Also the RX audio is pretty lousey. However TX audio is very good. I use external speaker which helps somewhat. I was going to buy the Alinco mobile 200 mhz radio but wanted to save a little money, but you get what you pay for.
weyforthr
Stafford Virginia
Are you programming via front panel or TYT software? What have you tried to do to start scanning? The default "key" to start scanning is "long press" key (front panel button) P3. That can be changed via software, and a channel can be skipped
I have the same radio and agree the RX audio is an issue. I have learned to just deal with it for now.
42
bobruzzo
W1AV
I cant get the TYT software to communicate with radio....keep getting error "check connection, retry, cancel" It shows correct port but baud rate 9600 in the device manager and it does show COM 11 being used. Under universal serial bus controllers it showing "USB-29A radio cable"
greyed out. Very frustrating!!!! I was able to do some programming via radio itself.
weyforthr
Stafford Virginia
Yes, USB is very finicky at times. My USB cable for the TH-9000D is listed as "USB-SERIAL CH340", also on port 11.
""USB-29A radio cable" greyed out."
Is "Show hidden devices" selected in the Device Manager's View list?
USB-29A is an RT Systems USB cable. Are you trying to use RT's software to program the radio? If so, they should help you out with your USB/Programming issue.
Just to make sure, is your radio the TYT TH-9000D mono band?
bobruzzo
W1AV
Yes radio is mono band 220 mhz. I noticed when I click "Model" the wrong freqs are entered, but you can change them. I changed them to the proper 220 freqs that show in the pop up box. Show hidden devices is selected. The software I am using is the TYT TH900D that I downloaded from Either Buy two way radios or Radioddity, I cant remember. I am sure that greyed out USB-29A has something to do with the problem. So at this point I am outta luck!
bobruzzo
W1AV
UPDATE:::: I actually was able to use the USB 29A cable that I use for my ICOM IC2730 uhf/vhf analog radio. The cable that came with the TYT 9000D is no good. So problem solved. I hope by using software I can get the radio to scan.
Chad1990
I’m not very familiar with these radios but I have three members of my hunting club that have bought them and I was trying to program them mind you all radios were bought at the same time and one off them is 1.25 m 220mhz and the other two are 2 meter 136mhz my question is the owners manual are all the same and don’t say if or how to change the band and all the boxes say are vhf no freq range can I change the band or will he have to return radio
chief21
Summer - Western NC; Winter - Tampa Bay FL
If you're talking about the TYT-9000 radios, I just checked several sites and all indicate the 9000 is a single-band radio... either 2m -or- 220MHz (technically, both are VHF).
