UHF Base Antenna
WB5ITT
Beaumont, TX
Both of them are 400-430 models...make sure thats the range you need.....Most lowpower UHF fiberglass antennas are not much more than a WIRE co-linear inside the fiberglass/plastic....Lightweight is a give away.....they are pretty much all the same...A Celwave or similar fiberglass will be heavier construction...however, if you are mounting these at roof top level or similar, they should work ok...the surrounding area may make the difference (air particles, dust, possible acid rain, etc)...
