I have a UHF MTS2000 Model III. I can select SCAN as a menu item in CPS, but when I program the radio, it disappears. When I go back to check the programming in CPS, it is removed from the menu list as well. Also, I cannot assign either switch to scan, it just turns red in CPS when I select it and says invalid. I have tested a channel with "automatic scan" selected and that works, and I can also program a 'user selectable' scan list and that works as well. I just cannot set any menu item or button or switch for SCAN.
