UHF/P25 Question
FireMedic658
Hi. Quick question. As I understand it, all P25 radios do analog FM. if this is the case, can I do P25 AND UHF at the same time, or in the same scan list--"channel" 1, P25, channel 2, UHF, etc?
TIA!
a417
what is the radio in question? more details are needed, as well as some clarification. p25 is a trunked radio standard, and UHF is a band...
KJ4NFP
Richmond, VA
Typically speaking...
Yes.
Although P25 is a trunking standard, it is also a conventional standard. It is often possible a radio is featured with p25 conventional and not trunking, but rarely (never that I can recall coming across) is p25 trunking featured and not p25 conventional.
More details on the model you are working with will certainly help, but I would be suprised if you could not do what you are attempting.
DeoVindice
P25 Underground
5150 Level
What do you want to at the same time, exactly? The radio will only transmit in one mode at a time, but many makes/models implemented mixed-mode receive. As for scanning, I don't know of any radios that don't allow both digital and analog channels in the same scanlist.
gatekeep
FAIL 01/93
New York, NY
Motorola P25 capable radios can do both analog and digital channels in the same scan list. Those radios capable of trunking can also do trunking TG's in the same scan list.
