tgrevers
Hello,
I just completed installing a Uniden UM435 Marine Radio into a boat this weekend. The radio came with a slow blow 6A fuse - the vessel is equipped with blade fuses in the power panel. The radio is mounted to the boat's center console, and all powered equipment runs through fuses located at the back of the vessel. Anything powered has its fuses located in the back, so there is no non-fused power running through the length of the vessel.
My question - the radio came with a slow blow 6A fuse. There is no 6A blade equivalent fuse on the market that I could find. Blade fuses are sold as 5A and 7.5A fuses, nothing 6A.
Can this radio be safely run on a 5A blade fuse?
Thanks,
-Ted
Thanks,
-Ted
