Unable to change serial number on second SDR dongle- windows 11 OP system-SDRTRunk
Colincolin30
Sydney Australia
I am trying to set up two SDR dongles to use SDR Trunk.
I want to get a wider band coverage. To do so you need to change the serial number on the second dongle.
Its a stock standard SDR dongle v3 nothing special. The first dongle is working on on SDRT Runk.
I have used the recommended software "tool" but get an error report which I have printed out below in this post.
I have contacted the manufacturer and had no reply. rafaelmicro.com
Any suggestions where I go to from here?
cheers Colin VK2JCC
C:\Users\User\Desktop\Serial change\rtl_sdr_64bit>rtl_eeprom -s 02
Found 1 device(s):
0: Generic RTL2832U
Using device 0: Generic RTL2832U
Found Rafael Micro R820T tuner
Current configuration:
Error: invalid RTL2832 EEPROM header!
Error: invalid string descriptor!
__________________________________________
Vendor ID: 0xffff
Product ID: 0xffff
Manufacturer:
Product:
Serial number: ¦??
Serial number enabled: no
IR endpoint enabled: yes
Remote wakeup enabled: yes
New configuration:
Error: string too long, truncated!
PDXh0b0
Woodland, WA
Looks like you botched it, there are supposed to be 8 digits..
If it's a legit rtl-sdr-blog v3......
Make sure that dongle is the only one plugged in..
Download this and put it in your rtl_sdr_64bit folder
After you have placed it in the folder, that dongle being the only dongle plugged in , open a cmd window in that rtl_sdr_64bit folder ( you can type cmd in the folders address bar then hit enter)
In the cmd window type
rtl_eeprom -w RTLblog01
Press enter
Once it's done, leave the cmd window open, wait a few seconds , unplug that dongle & plug it back in..
In the cmd window run
rtl_eeprom
Do the output now look normal?
Colincolin30
Sydney Australia
Thsnks for your reply.
I have not been able to change anything yet. I am well aware you need 8 numbers. That's what I am trying to do.
I think you missed the point I made in the email.
Any advice how to 'enable 'the change of serial number.
Colin
sunwave
Oklahoma
Colin
A forum search found the same issue.
This post SDRTrunk and 2 RTL2832 Tuners
Simple instructions:
Thanks for all the help. I reached out to Nooelec support and I needed to run rtl_eeprom -g realtek and then I was able to run rtl_eeprom -s 00000001. I now have the serial number enabled and written on both SDR tuners.
This is dependent on if your RTL-SDR is from Nooelec. It might or might not work with others. Especially RTL-SDR Blog dongles.
jtwalker
Gettysburg, PA & Fenwick Island, DE
Colin
Your command string in your post #1 above shows you are trying to change serial number to 02, which is not 8 digits. If you have typed 00000002 it might have worked.
mc48
Monroe County, NY
I believe you can run up to two with the same S/N. I run two V4 in SDR Trunk with no problem and it utilizes both.
