Unable to get volume on NTIRN channels
fits_51
dallas
Southwest Regional Communication Center was an nxdn system, but has now joined the NTIRN as talkgroup SWR. My TRX-1 picked up the nxdn channels with no problem thru a download from the Radioreference data base. I have since downloaded every combination of SWR that I can think of and all I get is squelch break which indicates someone is transmitting, but I get no volume/audio at all. I know the scanner is capable of volume as the weather channel comes over just fine. Scanner Support from Whistler has been excellent, but so far we have been unsuccessful in our quest. Is anyone else capable of picking up NTIRN on your whistler and if so what is the secret to your success.
KevinC
Encryption
Super Moderator
I'm everywhere Focker!
Looks like all the SWRCC TG's are TDMA, which that scanner can't decode.
South West Regional Comm Center​
Cedar Hill, DeSoto, Duncanville
DECHEXModeAlpha TagDescriptionTag
360038ca3TSWR PD Disp 1SWR Police Dispatch 1Law Dispatch
360048ca4TSWR PD Disp 2SWR Police Dispatch 2Law Dispatch
360058ca5TESWR PD SecureSWR Police SecureLaw Tac
360018ca1TSWR FD DispSWR Fire DispatchFire Dispatch
360088ca8TSWR Ops 1SWR Ops 1Multi-Tac
360098ca9TSWR Ops 2SWR Ops 2Multi-Tac
360108caaTSWR Ops 3SWR Ops 3Multi-Tac
360118cabTSWR Ops 4SWR Ops 4Multi-Tac
360128cacTSWR Ops 5SWR Ops 5Multi-Tac
360138cadTSWR Ops 6SWR Ops 6Multi-Tac
360148caeTSWR Ops 7SWR Ops 7Multi-Tac
360158cafTSWR Ops 8SWR Ops 8Multi-Tac
360028ca2TSWR EOCSWR EOCEmergency Ops
360278cbbTESWR Enc 36027encryptedMulti-Tac
360298cbdTESWR Enc 36029encryptedMulti-Tac
360318cbfTSWR Event 1SWR Event 1Multi-Talk
360818cf1TSWR Event 2SWR Event 2Multi-Talk
360408cc8TCH Public WorksCedar Hill Public WorksPublic Works
360438ccbTCH Parks 1Cedar Hill Parks Ops 1Public Works
360448cccTCH Parks 2Cedar Hill Parks Ops 2Public Works
fits_51
dallas
Thanks for your quick reply Kevin C. I have forwarded to my Whistler support guy.
hiegtx
Dallas, TX
Actually, the TRX-1 can do P25 Phase II. What it can't do is cope with simulcast.
When the transition first started, moving Dallas & Dallas County from their conventional channels to NTIRN, I set up my TRX-1 to use a wildcard & record everything it picked up.
Over the time I had it parked on NTIRN, it recorded hundreds of audio files. But when I downloaded them & started to review the audio, all were useless, too garbled to provide anything of use.
Harold
Texas
What site are you using? Be sure you have "Dallas Layer 1" not the Fort Worth "Layer 1". Check your squelch.
fits_51
dallas
I have all 750 channels in one scan list. I get a word or two, or a few seconds of continuous broadcast, or a D2 and info screen, but nothing in the way of 100 %. I am in southern dallas county and all I want to do is pick up the SWR talk group which is detailed in the first of this thread.
hiegtx
Dallas, TX
At present, the SWRCC cities (Cedar Hill, Desoto, and Duncanville) might come across on either Dallas Layer 1 or Dallas Layer 2. Both of those are simulcast sites, so your reception would not be 'better or worse' if you only programmed the specific SWRCC talkgroups. Once everything settles down, and all cities & agencies have converted to NTIRN, Dallas Layer 1 should be primary for public safety talkgroups, with Dallas Layer 2 handling the various departments and agencies within the cities that are not part of public safety.
fits_51
dallas
I tried to attach videos that demo what I am experiencing, but apparently a small video is still too big. I can get a partial transmission from some of the Dallas channels with audio, some I can understand, some every other word. And I can OCCASIONALLY see SWR PD1 which is the main channel I need, but no audio and no D2. I get a lot of squelch bars and a T and a D2 but no audio.
And thanks to all of you who are trying to help me out.
hiegtx
Dallas, TX
all the sites for NTIRN are set to auto fill
You've got quite a few more sites programmed, that you, likely, will not be able to receive in most of Dallas County. That in itself does not affect how you receive the site you need, but the scanner wastes a bit of time checking all these extra sites that are either out of range, or not of interest.
But the bottom line is still that the Dallas Layer 1 site, which is what you'll need for most all public safety talkgroups, is still simulcast.The frequencies for that site are using the state's license for 700MHz, so looking at the site map does not give the locations of the various sub-sites (transmit towers) for this site.
You can access the site map for Dallas Layer 2, which uses most (if not all) of the frequencies for the analog Dallas Local Government. I suspect, but have no way to confirm, that at least some of the 700MHz sites are co-located on the same towers as Layer 2. There were a couple of sites added (from what the old, analog, system used). Another site (not reflected on this map) is on license WNXM603, which includes 4100 W. Illinois, where DPD Southwest Patrol Division, as well as other city departments, are located.
You indicate that you are in southern Dallas County. That would put you somewhere between the site on the lower left corner and the site on the southeast side. Those two, plus the two sites in the downtown.Fair Park area,means that their signals would arrive at your scanner at varying times, out of sync from each other, That results in the Simulcast Distortion that you will find mentioned in a high proportion of threads here in the forums, regarding problems with monitoring various systems around the country. If you are very close to one of the sites (like a quarter mile or so), that very strong signal might be able to override the out of sync signals from other sites. From a fixed location, such as your home, you might be able to use a directional antenna, such as a yagi, aimed at one specific site. That way, it's signal will be much stronger than signals from towers not located in that direction. On the Simulcast Distortion page in the Wiki (linked above), there are a few other suggestions of things to try. One them might work, or maybe not, but you could at least try them. One thing you might try is, with the scanner sitting on your desk or a table, place a taller metal object, such as an aluminum baking pan next to the scanner, and try it on various sides of the scanner. In some cases. this may null out out sites, or at least reduce their signals, leaving the scanner receiving only one site.
Most of these suggestions would be impossible, nor practical, when you are out driving around in your vehicle.
fits_51
dallas
I am told that our three existing towers, physically located in Duncanville and Cedar Hill and DeSoto are being patched in to this system. I have no way of verifying if this is true now and/or planned on. Does anyone have a work around for the synchronization prob.
fits_51
dallas
I l/o all trunking except dallas layers 1 and 2. I also l/o all channels within NTIRN except the tgrp SWR. I get lots of signal strength bars, and a black back ground S constantly and an actual squelch break with a tad of conversation on some of the swr channels. The channels are there, I just can't get them to behave normally. With what you responders have said, I'm hoping it might be the sychronization thing as I do get partial transmissions.
ve52001
Duncanville, TX
I'm around the same area, and my TRX-2 does poorly on this system. The only way it might work ok, is with a directional antenna pointed at the far south west corner tower that is closer to me. I just haven't messed with it yet, seeing how I am using my Unication G5 to monitor all the SWR talkgroups. You might have to end up getting a Uniden SDS100 or Unication G5 if you need a portable. The only thing about the Unication G5 is there are limitations, but I knew that when I got mine.
