Unication G4 issue
hruscher
I have a pager programmed for a customer, he has 2 G4 running the same firmware, same programming. He contacted me today and said that one of the two pagers, is showing no signal at all. He sent the pic below.
I have never seen the C emblem next to the battery like that and I cannot find it in any of the manuals. What is it for? I also noticed that it is showing off duty, I gave him instructions on how to fix that.pager.jpg
Enjoi19
Are they scanning trunked or conventional frequencies?
If it's conventional, you would have no signal indicator unless it's receiving a transmission.
hruscher
I told him to switch antennas and see what it does
Ok. Those are known to push the center pin on the SMA down causing it to not contact the antenna. Maybe something to check.
It is scanning the TXWARN 7/800mhz system
