Unication G5 scan multiple systems?
PhillyPhoto
Wethersfield, CT
It was in limited beta assigned based on the model number of the pager to those who originally signed up, and is no longer available. Unication appears to have stopped support for it.
The firmware is locked to the serial numbers hard coded in the firmware itself, not just model numbers.
Also, it wasn't a "scanner" like we're all used to where you tell it to watch systems A, B, and C. You would put in a frequency range and it would scan through it to find activity that way. It was a really terrible implementation and I ended up selling my G5.
bob550
Albany County, NY
That doesn't fill me with a lot of confidence regarding any future Unication "scanner". I would also fear that performance would suffer as a result of attempting to cover multiple bands. I think I'd be content with the ability to scan multiple P25 sites and systems and maybe in combination with analog conventional frequencies.
W8KIC
Shaker Heights, Ohio
It isn’t exactly news that the Unication PAGERS aren’t ‘SCANNERS’ and the company has never attempted to market them as such. What they do produce is a receiver that my own SDS100 & 200 simply cannot duplicate and that’s a measurable draw for numerous monitor enthusiasts who actually appreciate being able to listen to complete transmissions. I may well pick one up in the not to distant future but regardless of what buying decision I ultimately end up going with, I know full well what the G4 and G5 are and of course, what they aren’t.
Giddyuptd
Here and there
The scanner term comes from people who refer most to use these over NAS since most tend to goof that up and cause issues.
Key thing is majority whom suggest g5 or other modesl own scanners or sdr where data can be collected properly and then programmed in or are in know or techs within a system knowing the proper data availablein their area or ties to others elsehwere. The average joe thinks it'll all be freely out there for the g5 in terms of trs data which isn't true. Thus you get sour thoughts or they expect to turn it on and it magically scan everything.
For a agency they work as needed and if programmed right one cam monitor a 700 system legitimately programmed with the specific data without needing affiliate issues while using a portable for the rest if on conventional vice versa.
I think they are good pagers and added tools specially in rural depts where it isn't ideal to have your normal average vol fire or ems needing to have a subscriber to a trs nearby but they can monitor while using their conventional local channel on portables or using dual band mobiles in rigs on said system cutting down on subscriber fees in portable end keeping the handheld on conventional that dispatch does monitor anyway.
I've seen various configurations and we all know agencies make penny pinch decisions while elsewhere spending carelessly which makes no sense but it happens.
Like a two way radio you cant hear it all unless you have a couple on you which you see command or comm officers have. Why many favor still single band radio over multi band. Doesn't do any good when you're parked on a tac and needing to hear soemone else on a different band. It could go on.
The g5 and others are decent pagers and tools to add to existing setups not to replace.
But they do make a handy scanner per say with limitations as any radio has limitations anyway.
sefrischling
Public Information Officer
New London, CT
No being able to scan both Trunking and conventional is a collosial deal breaker for me. Too many mixed PS systems in my area.
They are not designed as scanners. They are designed as public safety pagers, I use a G3 to monitor my Fire Dept's VHF dispatch, while also monitoring our mutual aid dispatch, a mix of UHF and VHF, along with our town police "talk around" which is VHF. I use the G5 to monitor our town police, who are dispatched on a Phase II 7/800 system ... yes their talk around is VHF and dispatch is P25 trunked ... as well as the State services such as the Fire Coordinator, HazMat and the State Police that work in our town, who are all on the Phase II 7/800 system. The G3 and G5 are better than any scanner around for what they are intended for.
bob550
Albany County, NY
Was it unication doing the beta firmwarre or was it someone that knows how to program?
It was Unication. If you read through this thread, you'll see that the beta firmware is not the answer to your dreams. In fact, several posters mentioned downgrading back to version 1.3. I'm sure there's a good reason that Unication abandoned this effort.
jabbeaux
Germany
Yes you can, I'm doing it right now in my G5 with firmware version 1.40-T02J. Here's the user guide from Uni how to set it up.
FWIW, I've noticed no change in receive quality or missed two-tones between firmware 1.31, 1.32, and 1.40. I'm not aware of 1.40 removing any features. Can't recall it breaking any existing. I'm not sure why people downgraded to be honest. If I stop using the scan feature, I'd just not use that menu option. At least 75% of the time that's what I do anyway. Knob positions and menus are the same. You have to dig through menus to get to scan feature and activate it. I always wondered why people downgraded instead of just not using that extra feature.
palmerjrusa
Frederick
I've owned a G5 for less than a week and it blows my Uniden scanners out the water. With the supplied antenna it receives and decodes systems in adjoining counties that the Unidens need tuned antennas for. It's also built like a tank, has great audio, and battery life is incredible.
Just a shout out to Ray's Pagers for his excellent customer service.
Giddyuptd
Here and there
Once you figure out the software it's pretty nice. I just boggle on conventional why it misses soem traffic or doesn't un mute sometimes. Have the settings set as others and some zones have this issue.
palmerjrusa
Frederick
The software was pretty daunting at first but after a while, it clicked, and finding it straightforward now.
Continue to be amazed at the G5's performance, it's sitting here beside me decoding systems with its own antenna that I have to switch antennas on the Unidens to receive.
Bryce031
Mullica Hill, NJ
In reading the threads here, I have to think there is a way to manually enter multiple control channels from different systems. I am looking at the New Jersey Interoperability Communications System (NJICS) and I believe we are able to listen to any TG on any system? Is there a way to 'add' control frequencies to a zone ("system") to add additional towers to what is being scanned? Ideally, when speaking about NJICS, I'd like the ability to give each Troop of NJSP its own knob position that would grab traffic regardless of my location in the state. Is this possible or reasonable with the G5 or a pipe dream?
jtwalker
Gettysburg, PA & Fenwick Island, DE
You can add multiple sites to a system in PPS and then assign this to a knob position, but the G pager will connect to one control channel with an acceptable level of decode and stay there until decode quality deteriorates to an unacceptable level. It will not scan sites.
ofd8001
Louisville, KY
What I've seen is kind of like what JTWALKER says: The radio "latches on" to a site where it receives an acceptable signal. Once that signal falls too low, the radio looks at other programmed sites/control frequencies for more acceptable signal, then latches on to it, until that one falls off.
So it is sort of like a "hybrid" scanning, only moving on when the signal drops off.
But you could add multiple sites, the maximum number I do not recall.
So how do I get it to actually scan? I don’t see any menu options
It's not a scanner, that said you can set up to 15 conventional analog, P25 or DMR (if you have the upgrade/addon) frequencies to scan, or you can scan through up to 63 talkgroups on a single site/system plus a wildcard (64 without a wildcard) per knob.
Nascar18
Southeast Massachusetts
Are the instructions basic to do that feature?
