Unication G5 Will Not Power Up And LEDs Flicker
JASII
Memory Capacity
My Unication G5 will not power up. When I try to charge it with either the drop in charger or a micro USB cord, the top three LEDs just flicker.
The battery that is in it was installed about April 2023.
Is it likely that it just needs a replacement battery or are the flickering LEDs indicative of something else?
Try removing the battery for 5 minutes and reinstall it. If not it may be the battery.
Bmacs
Southern NH
Earlier versions of the radio had this issue when the battery gets too low - you need to disconnect the battery and re-connect and all will be fine. I have taken to keeping a small Philips screwdriver with me to be open to remove the battery when needed... pain in the @ss
Newer hardware does not behave this way...
