Unication Scanner
kc5igh
Velarde, New Mexico
So, assuming that this is legitimate AND it ever makes it to the United States market, how would this likely be different from the Unication G5?
Would it be multi-band, VHF high band, UHF and 700/800 MHz? Would it still have paging functionality?
Wow! Sign me up for a Unication scanner!
I'm very happy with my G5, but I'll definitely want to get one of their scanners when they finally become available. I'm guessing it'll be pricey, but Unication makes good stuff!
-Johnnie (KC5IGH)
APX7500X2
NY/CT
You mean the APX8000 speaker mic? Yes, they are about the same size.
Nope not what i meant......
I meant the internal electronics in an APX8000 minus the TX would easily fit into a current G5, but not in the current configuration.
What I intended to convey, indicate, or refer to was that the G5 has the space to do it and on the sales and marketing side of things would ultimately be a lager profit, making 1 physical piece of equipment and using SDR practices to get what you want in it.
Motorola is doing the same thing, the APX8000 and the 6000BN are the same chassis, the APX900/2000/4000/XPR75XX chassis are all the same, just insert the electronics, put on the case and use the SDR software to make it what it needs to be
